Drivers side fuel imbalance?
While the car was on the hoist I checked for any carbon deposits on the exhaust for leaks and I can't see any puffs of carbon anywhere. Running 2 wide bands Denzo #234-5117 which is the equivalent to Bosch 17014. Before I get hammered the ecm is Fitech 70050 that was purchased in 2017. The car runs fine, its just the drivers side lean condition that I want to correct on this fairly fresh engine.
Attached are the spark plug pics, 2-8 look the same except for #1. I'm coming from a SBC platform and fi is fairly new to me so if anyone can suggest where I should look into at this stage it would be much appreciated. Thanks in advance.
1-3-5-7 plugs before I changed #1, its clean.
#1 plug before I changed it
New #1 plug with about 50 miles on it and new 42lb injector from today.
If its the drivers side o2 sensor wouldn't the whole bank be getting mis reads? Why just the one cylinder plug looking clean, has me baffled? Intake leak.....gasket?
Do you have a scan tool?
Was this tuned?
Should be able to see misfires if it wasn’t turned off in the tune.
Possible wiring issue if you already changed the coil and wire.
No spark generally give you a lean condition because you have extra oxygen in the cylinder, and the O2 doesn't read gasoline.
When you hit it with a temp gun, make sure it's up to temp first, and if you spend a couple of minutes doing it, you'll see a pattern, hit each tube in around the same spot.
What coil packs are on the car? New, used? You can try moving #1 around, also, it looks like you're pretty detail oriented, but run some boot grease if your not, and make sure the wires are snapping on.
When I show the AFR and trims for the drivers side and pass. side it still seems to add fuel to the drivers side in the 14-2200 range. Gonna have my tuner plug in his laptop while driving and have him check things out as I'm driving, I've already sent him some log files and he mentioned things still need to be tweaked.
What coil packs are on the car? New, used? You can try moving #1 around, also, it looks like you're pretty detail oriented, but run some boot grease if your not, and make sure the wires are snapping on.[/QUOTE]
exhaust
rpturbo,
Ha! funny that you mention this! my tuner gave me his infared gun to check exhaust header temp.
After taking the car out today for a drive, I used the gun when I got back home on the drivers side and here's the temperatures for 1-3-5-7 cylinders.
597- 608- 680- 667 degrees.
I guess the first 2 are closest to the fans so I believe they got cooled a bit.
I already swapped out the #1 to #2 coil and spark plug wires.
Don't get it really cause the car runs fine but when logging it seems to compensate fuel at the 14-2200 range.
Here's video of the first startup back in Nov/ 21.
I'm not using a GM ecm the system is a Fitech 70050 which has been working out okay considering I purchased it back in 2017, well before Holley came out with their Terminator stuff otherwise I'd get that now.
The clamps are a overlap style that should seal, didn't use the band clamps from above. I didn't notice any carbon deposits anywhere along the exhaust.
Also I swapped the o2 sensors last week thinking it possibly will follow that sensor, the drivers side still enriched, so it wasn't that.
I mean I REALLY like them..
Pic of the #1 plug on the left after most recent drive showing signs of carbon, plug on the right is the one I replaced thinking I had a defective spark plug. Another good sign was when I put the heat gun on the #1 header pipe it registered 700 degrees. I'll post up if things change from here, tks.
When I most recently took the car out I was more concerned with checking the drivers side fuel trim which showed a reduction in 20% adding of fuel from the lean condition that was happening. I have only put 5-10 miles at most, the main purpose of the drive was to check both fuel trims and see if they're close to the 3-5% plus or minus of one another. They are close but the drivers side is still learning and making the necessary slow adjustments. Plus my tuner needs to make some adjustments after seeing the the fuel log but that's gonna have to wait a week or so because he's just getting over Covid.
This is one time that I was happy to see carbon buildup on a spark plug. I'm sure once put some more miles on the car that the plug should hopefully have a tan hue like the others.
