24x Swap no Spark
Would it start even if the distributor is not in right? The 4x setup I was running would start even if it was off and then I would set it using the cam offset pid.. I segment swapped engine and engine diagnostics.
Can some one help me out, total noob here. Pulling my hair out. Thought it was a ground issue but same thing no spark. Not sure if I flashed the correct tune either, got a little exited, could someone take a look an see if my issue is the tune or mechanical ?
I seem to recall there being a few pins off between the f body and truck PCMs.
What cam position sensor are you using?
I never did a swap like what you're doing but I have done a Gen 3 to Gen 4 swap and ran into a problem that required the cam sensor plug to be wired different.
