Knock sensor code help! P0327 and p0332
i ended up pulling the intake for a 3rd time and threw in some 50 buck a piece duralst sensors and problem solved, the codes never came back. Drove over 300 miles and so far so good. Previously it would throw both knock sensor codes immediately after clearing and driving. To anyone that encounters this issue i suggest testing the knock sensors while you have the intake off dont just check resistance because the dealer ones i had checked out, what i didn't check initially is to see if they put out enough millivolts when tapping on the cylinder head or engine block to recreate engine vibrantion. In my case i would say dont buy from the dealer or ac delco buy some that are reasonably priced and check them before putting the intake back on. I just blew $240 dollars on some dealership factory sensors all to do double the work
Thanks.
The motor had just got its first real tune since a complete rebuild. It’s a 5.3 Vortec with a mild cam, flat top pistons (10:1), 30 lb injectors. The truck had never thrown this code before. I had used mid-grade gas, but on my way home from the tuner, I filled up with regular (87 octane). Could the lower octane possibly cause the code? I didn’t think so because the code indicates a fault with the sensor.
Also, can sensitivity be adjusted through tuning.
Thanks.
