PCM versions/
Old Jul 5, 2023 | 07:35 AM
klinznilk's Avatar
Default PCM versions/
I currently have the 02 FBODY PCM -- P01 0411
I am wanting to go to 3 bar OS as I am upping boost to make of 20ish. My 3 bar map I can put the liner and offset in HP tuners however I can not go to 3 bar OS it appears.
My question is this:
What PCMs will be plug and play into the fbody platform (2002) and can be used. I am well aware of HP Tuners costs/licences and can change VIN on new PCM of course.
Thanks in advance.
Old Jul 5, 2023 | 08:39 PM
B52bombardier1's Avatar
I think . . . think . . . that a later year P59 will be the closest PCM that might possibly work. But its not a plug and play kind of deal. There will be some slight re-pinning of wires required and the grounds to a P59 are different. It also has a blue and a green connector that has different notches - swaps are possible here.
The benefit of the P59 is that its memory capacity is twice the size of your P01 0411 - 512k memory vs 1024k in the P59.
Maybe somebody else will chime in. Go look at LT1swap.com to see the detailed differences between the P01 and the P59.
Rick
Old Jul 5, 2023 | 09:06 PM
RonSSNova's Avatar
I just looked at two 02 Camaro tune files, both stick and auto.
Both show 3 bar available.
Sounds to me like your 0411 wasn't originally in a Camaro?
What does it say under "Edit/Calibration Details"?
Old Jul 6, 2023 | 07:03 AM
klinznilk's Avatar
From what I can tell the only 3 bar option I have is Speed Density.
I still have/run a MAF and would like to retain that most likely as my piping for blower has the card style in it already.
100% original 2002 Pontiac Trans Am PCM as I am original owner.
Old Jul 6, 2023 | 10:11 AM
RonSSNova's Avatar
The MAF doesn’t know boost, only airflow. Therefore you don’t need a custom OS. Or a 3 BAR map sensor.
The ECU has a hard limit for MAF airflow. So depending on the inlet tubing size, you may exceed that, and will need to scale the MAF sensor. There is a sticky on that by ddnspider I believe.
Most folks just do a 3 bar SD tune for the high hp boosted stuff.
Old Jul 7, 2023 | 03:22 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
The 2 and 3 bar SD custom operating systems do NOT break your MAF. You still have the option of running a MAF with either of those. As an example, my former work truck that my Dad now owns has a Whipple running low boost into a 4.8L. I tuned it with a 2bar sd os, but still tuned the MAF as well, because it was nowhere near maxed out. On my current GTO that easily maxed out the MAF with a turbo, I ran SD only until recently. Right now I am between turbo kits on it, and am still running the 2bar os, but with the MAF back on it for now. When I returbo it, I may take advantage of the card style MAFs available now and scale a few things to use one.
