Detuning LM7 to 220HP
I guess pulling around 10-15 deg at WOT should do the trick.
Any thoughts?
IF it's at the wheels as Minytrker says above, you might already be close to there since they can't measure flywheel power unless they rip your engine out to do it. Not happening.
Maybe also run it quite lean for the dyno session. I doubt it would hurt the engine to do a few lean pulls to 5400rpm or so
There has to be a way to put a "stealth" restriction somewhere that "they" won't detect but is removeable/reversable.
Is a state-owned dyno used, or a private one?
There's always "extra" padding under the gas pedal....
Just so we know, exactly what kind of car are we dealing with here?
Maybe a hidden obstruction in the intake tubing could work
edit another is run rich, like 1pt richer, ie- current PE is 12.8, set it at 11.8. another is very dirty air filter lol
