Programming P59
Old Dec 13, 2023 | 03:00 PM
Painters's Avatar
Default Programming P59
My is os is12606807 from a 2006 avalanche I am going to use a 4l60e 2 wheel drive transmission do I have to change transmission settings in the os.already turned off vtd,dtc’s for rear o2 sensors.and should I do something with the emissions on the os.help please.
Old Dec 13, 2023 | 07:18 PM
mrvedit's Avatar
Moderator
First, welcome to the forum!
Next, to get help here you need to give us more detailed info, explain what your goals are, and try to use the correct terms. For example, "settings in the os" is confusing. I think you mean "settings in the tune". The specific OS is not that interesting.
I have no idea what your goals are - why did you have the DTCs for the rear o2 sensors turned off? Deleting the cats?
Didn't a 2006 Avalanche come with a 4L60E? If yes, then what are you asking?
No idea what you mean with "should I do something with the emissions on the os" .
Do you have HP Tuners or equivalent to change the tune? If not, how were the DTCs turned off?
Old Dec 13, 2023 | 09:05 PM
Painters's Avatar
yes the tune.I am going to do a 5.3LS swap and the avalanche did have a 4l60e 4x4 I have to use a 2 wheel drive transmission.I have a obdx pro vx and I am using lsdroid to read/write to pcm.I used universal patcher to remove vtd,dtc’s and I am not running cats on it.
Old Dec 13, 2023 | 10:21 PM
mrvedit's Avatar
Moderator
OK, thanks for the updated info.
Changing from a 4 wheel drive to 2 wheel will not affect the tune. Make sure you get a 2006-2008 4L60E as it has to have the Input Speed Sensor (ISS). 2005 and earlier did not have ISS. (Well a few 2005 may have.) 2009+ are electrically different and won't work.
