ACES Blackjack EFI standalone
I'm about to pull the trigger on this system. Question is: Does anyone have experience or
second-hand knowledge about the reliability, and usability of this product.
I have done a bit reading all the reviews online. Seems to be all the usual questions.
A lot of people having install problems, but this happens with others I have looked into.
The reviews are 2+years old. Any opinions, reviews.
Why not just stick with a GM system or Holley Terminator X. With either you have a community of hundreds of thousands of people, hundreds of thousands of forum threads, thousands of in-depth YouTube videos, some with hundreds of thousands of views.
Yes there are other less-popular high end systems, but they are mostly for extreme or unusual engines.
I'm not saying its a bad system, but there is little/no online support.
I Googled "aces fuel injection forum" to see if they even have an online forum and it appears they do not. However many other car forums mention them, but not in a nice way.
You just need a "411" PCM, a $200 harness from ebay, injectors (not from ebay!) and HP Tuners and you will have a super reliable system with infinite support available here, on YouTube and elsewhere.
A Term X blows it out of the water for not much more but a factory PCM would work just fine as well for this combo.
for boost you have several options when using a p01 or p59
hptuners
efilive
boostOS with pcm hammer
They are all pretty similar in this context with each offering slightly different costs/features/etc. One isn’t necessarily better than another, just different.
Just saw this post, sorry I did not see it before. I went thru the Aces EFI set up on the complete Jackpot system. It was a nightmare. I got the complete system, coils, injectors, manifold, everything.
I got it all installed on my stock LS1 with a manual trany and it ran like crap. It ran super rich, it would not learn, kept going in and out of closed loop. It was showing faults they told me not to worry about it. It fouled out a set of plugs in about 6 miles.
I called the tec support, they told me to hire a tuner and that they (Aces) could not fix the problem. They also told me that their system only learns the fuel tables that's it. I tried to explain that they advertise a "self learn" system.
It did not seem to matter. I finally had to return the system to them on my own dime......
Just food for thought.
i still wouldn’t touch one of those ecus but in this case unfortunately I don’t think any ecu would have made you happy with its ‘self learning’ if you expect it to learn everything.
