L92 Injector harness sequence and P0300s
Old May 8, 2024 | 05:24 PM
FastGas's Avatar
Default L92 Injector harness sequence and P0300s
I'm having random misfire and bank 1 lean codes after swapping injectors in a 2008 L92. I'm starting to think I may have mixed up some of the injector wires. Is there a way to tell which plug goes where for cylinders 1, 3, 5, 7? I'm using an aftermarket intake and fuel rails. I spray around with carb cleaner and didn't find any vacuum leaks. Engine idles rough and doesn't tolerate load. The LTFTs on bank 1 quickly go up to 30 at idle. LTFTs on bank 2 are normal. Thanks in advance and I apologize for the newbie question!
Old May 9, 2024 | 12:51 PM
LilJayV10's Avatar
Are the injectors new/used?
Old May 9, 2024 | 08:04 PM
FastGas's Avatar
Aftermarket FAST 65lb injectors. Basically, im wondering if my harness rotated 180 so 1 is plugged into 7.
Old May 9, 2024 | 08:16 PM
LilJayV10's Avatar
#1 PK/BLK TAN
#3 PK/BLK PK/BLK
#5 PK TAN/WH
#7 PK OR/BLK
This won't cause one side to be like that, but did you update your tune with the correct injector data?
Last I knew, FAST didn't have any data for the stuff they sold.
Old May 9, 2024 | 10:37 PM
FastGas's Avatar
#1 PK/BLK TAN
#3 PK/BLK PK/BLK
#5 PK TAN/WH
#7 PK OR/BLK
Awesome, thanks, i will confirm. I am using a Black Bear auto cal and tune they provided. Bank 2 is running great with good LTFTs, bank 1 is misfiring and running like crap with high LTFTs.
Old May 18, 2024 | 06:58 PM
LilJayV10's Avatar
You ever get this figured out?
Old May 18, 2024 | 07:44 PM
FastGas's Avatar
Got it figured out. The oxygen sensors were both very, very bad or fakes (ordered from Rock Auto). On to good problems now!
Old May 19, 2024 | 02:24 AM
LilJayV10's Avatar
Got dam, belt wrap for days.
Nice
Old May 19, 2024 | 09:36 AM
Nice
It got a grip for sure....
Old May 20, 2024 | 11:47 AM
FastGas's Avatar
Thanks. My fuel trims have flipped now but they are consistent. Time for the tuner to take another look after some more logging
