Let's have a FUEL thread.
87 octane is unleaded available everywhere.
In the cities, we have a second choice Premium here in state is 90 Octane ( "Advertised Octane, but questionable )
Most communities have an airfield where one can obtain 100 LowLead Aviation gasoline.
It has been my practice for high compression motorcycle and Ice racing engines to run a 50/50 blend of 90 Octane pump gasoline and 100 LowLead. Never had any problem with crude high compression carbureted engines.
Question here regards " spiking my 90 Octane bulk fuel delivery with around 10 % by volume of 100 octane LowLead Avgas.
Possible risk is fouling or destruction of wideband 02 sensors.
Fuel injected piston aircraft seem to function in closed loop with O2 sensors.
How LOW is 100 LOW LEAD ?.
edit : No Longer a LEAD thread, we are into ADDITIVES now.
Pushing 190 kPa into the gen3 5.3 Liter, Bottom of the 4000 and 4400 rpm columns I have 9 degrees spark, and getting 4 degrees KR. Yes, we are just a tad past the ragged-y edge of 90 octane viability. I have added a full gallon of Berryman's B-12 Chemtool, Great stuff: Contains Toluene, Acetone, MethylEthylKetone, Isopropyl, Methanol, 2-Butoxyethanol- Pretty much all the good stuff, and only $20 per gallon.
.... Question: What easily obtainable volatile solvent should I add to my next fuel delivery for best Octane per Dollar ?
Acetone, Toluene are both available in 5 gallon cans here... Which is better ?
anything else recommended ?
Last edited by Full Power; Aug 23, 2024 at 05:53 PM. Reason: No longer a LEAD thread, we are into Additive(s)
Here in Cali we have 87, 89, and 91 most commonly available. 93 does not exist here.
Are Fuel injected piston aircraft running in closed loop with Oxygen Sensors surviving on a steady diet of 100 Low Lead Aviation Gasoline ?
IF O2 sensors on pistron aircraft can function with 100 LOW LEAD, than I can use safely as an Octane Enhancer for tuning and or high boost operation.
As I detailed in OP, the best grade of Motor Gasoline available on the road system here is rated 90 Octane, and that is questionable, as it shares hoses and fuel delivery compartments on delivery trucks that also move much greater quantities of 87 octane. We also get anomolous seasonal refinery formula changeover(s) that will give LOYS of knock retard.
As well, many remote fuel stations in this state and Canada only have 87 octane on tap.
One can try to drive gently, but a viable option is to carry a couple 5 gallon cans of 100 LowLead, or a can of Toluene for emergency use. Either product will keep indefinitely if stored in a well seeled STEEL container.
................. Again, the original QUESTION is: Will 100 LL AvGas foul an O2 sensor ?
I have had no problem with long term use at 5% concentration, but curious how it works on piston aircraft .
Cruise by small general aviation airport shops and ask. A lot of times you get it for free. They can’t legally put it back in a plane after its drained without a permit. So most shops have tanks of the stuff they have to pay to get rid of as hazardous waste. We gave away tons of it to airboat guys.
50/50 ethanol/methanol blends will go a long way. Even 30% blends are better than 91/93.
Toluene/xylene blends can be semi cost effective as well if you buy drums of the stuff.
How much Lead per Ton ?
Is it a fact that modern fuel injected aircraft piston engines run in closed loop mode with Oxygen Sensors ?
How much 100 Low Lead can I blend with Unleaded pump gas and safely not destroy my Wideband sensor ?
As I say, I have been adding 2 to 5% AvGas to my bulk fuel deliveries since 2016 without issue.
Low lead is a misnomer as it has less lead than "normal" avgas, but still a ton of it, still too much for most O2 sensors.
Also thought this was interesting. I never knew that leaded gasoline was basically deadliest product in the history of the planet.
Berryman's B-12 Chemtool injection cleaner is only $20 per gallon can.
%85 Acetone
%10 Toluene
A bit of MethylEthyl Ketone, 2-Butoxyethanol, Isopropyl.
My math indicates B-12@ 130 Octane x 1 gallon = 130
90 Octane x 19 gallon = 1710
..........19 to one mix..........20 gallon blend = 1840/20= 92 octane
4000 and 4400 rpm columns bottom out at 9 degrees spark advance, and I am getting 4 degrees Knock Retard.
I am riding just a bit OVER the ragged edge of 90 Octane safe zone.
Rick
IF there was 93 octane pump within a thousand miles I would be running THAT.
Best obtainable Unleaded in this state is 90 Octane. I have tuned for, and run 11 PSI manifold pressure on a supercharged 4.8 for 8 years without any problem nor parts breakage. In my limited experience, 90 Octane, 11 PSI and 11 degrees spark "Love you Long time".
New project is a gen3 5.3 208/214 TSP Low Lift cam, 13 PSI and Spark advance at 9 degrees MINUS 4 degrees KR - I'd say motor WOULD like more Octane, if I could get it.
I just turned up the BE fuel in the 3600 to 4400 rpm range by 11%-- When in doubt POUR MOAR gasoline on the fire.
I think the better solution would be 50/50 windshield washer fluid from a progressive controller and a 5 GALLON tank.
