Boosted 4.8 Won't Run Right!
I have a 4.8 build I can't get right to save my life. Build specifications are stock 2000 4.8, Turbo 400, Stock PCM, Siemen Deka 80s, 78/75 Turbo running on Speed Density with a 2 Bar Map.
I had a reputable tuner do a base tune on the truck to get it up and running. It ran and idled great, however when you would go to drive it the truck wouldn't want to go over a certain RPM range and would sometimes die after coming to a stop. After getting a log we decided that he forgot to turn off abuse mode. However, in that log we found out that I forgot to plug in the IAT sensor. After plugging in the IAT sensor the truck runs like absolute garbage. Unplug the IAT and it runs relatively fine idling a little high and having the idle stick occasionally. I have gotten a log, which I can post with the IAT plugged in and after having my tuner and another tuner look at it nothing seems too out of the ordinary and it looks like the truck should be running fine, but it's not. You have to pedal it to get it started most of the time, and have to pedal it for it to stay running so it doesn't die. And when it does want to idle on its own without pedal, the idle will be anywhere from 400-1,200. Along with the log looking good, I have also tried a leaner tune, a richer tune, checked for vacuum leaks over and over, checked for fuel pressure, tried 3 different IACs, 3 different IATs, a TPS, read plugs, checked injectors, all to no avail. The truck also has no codes.
I am at a complete lost, I have been fighting this issue in my spare time for the past couple of months and I really want to get it right before I have to put it in storage for the winter. I will post the tune file and the logs below, if I can figure out how. Any suggestions are appreciated.
Thank you!
IF your "Tuner" built a fuel map (VE table) with OPEN CIRCUIT IAT, you need to do two things:
1) fire your tuner.
2) Build a new VE table.
Do not despair. 4.8 is A: the toughest most durable gasoline engine since the slant six.
B: Tuning "window" with 4.8 is very wide due to short stroke, small bore, LONG rods. Basicly as close to bullet proof as any V8 engine inexistence.
Lovely. I know little to nothing about tuning which is why I paid a rather well known and high regarded tuner here in the midwest $300 for the base file. That is extremely aggravating and unfortunate, all the while he has been telling me "everything looks good.".
IF he tuned the motor to " RUN" with OPEN Circuit IAT, which is equivalent to MINUS 40 degrees, THAN it will certainly be a bit OFF when actual ambient temperature is used to modify fuelling.
I see some pretty funny idle airflow settings, looks a little high for a 4.8 liter.
I'd strongly recommend getting your own HPTuners interface, eat the credits, and tune it yourself. You'll have plenty of time to learn.
4.8 is a pretty tough- and forgiving motor.
He charges by the fukups.. $30 each.
Not unusual. Around here, the local "hotshit tuner" is $600, and a dyno pull is $250 more. All to get a shitty tune that wouldn't run well enough to pull the car onto the trailer.
Time to learn to do your own.
Are you still using the Maf? In Airflow, Maf shows 14500hz, Dynamic air shows over 8000. Are you running SD or blended?
