Simple output when engine is running?
Old Nov 21, 2024 | 11:56 AM
AwesomeAuto's Avatar
Default Simple output when engine is running?
I'm swapping a car that uses a push button start. The car's original ECM would send a signal once the engine was running to shut off the starter.
Now, the starter runs continuously, so I'm having to manually shut it off.
I've tried a handful of things with the stock truck PCM to output something when the engine is up and running to shut off the starter, but so far nothing reliable.
Before I order an RPM switch or program an arduino to read the tach output, is there something more simple that can be done to trigger a ground once the engine is running, or above a certain rpm?
Old Nov 21, 2024 | 03:12 PM
wretched73's Avatar
No answers but curious.
I did a swap in a G37 with a push button start but couldn't figure out how to get it to trigger. I used a second button to a relay to actually trigger the starter. The stock button still powers the car and the Holley.
Old Nov 21, 2024 | 03:23 PM
The original ECU in the car would send a ground to the signal wire on the starter relay to turn it off. That's all I need is a ground.
An RPM switch can be had less than $100, but getting one that allows low RPM activation usually means sourcing custom made ones.
I could have an arduino trigger it from the TAC signal for about $4 and 30 minutes of programming, but was hoping for something a little more clean using the existing hardware/software.
I don't think the truck PCM has a working shift light output and I'm not sure what other unused pins could be repurposed with HPTuners.
Nothing obvious jumps out, that's why I was asking if anyone here had figured out some trickery to make something work.
Old Nov 21, 2024 | 04:49 PM
Full Power's Avatar
Analog Solution: 50 amp momentary START switch. Wire direct to starter solenoid with 10 gauge wire. DONE.
Old Nov 26, 2024 | 02:03 PM
I ended up programming a $5 Arduino Nano knockoff to read the Tach output wire and control a relay.
Using an arduino gives me the added benefit of it being capable of a lot of other things down the road.
