Which P59 PCM do I need?
I was thinking it had to come from a Suburban? What years?
I am not sure which vehicles these came out of but the hardware numbers should guide you: They made P59's with the IAC hardware (drive by cable) up to 2007. Hardware (not service) numbers: 12575502, 12570558, 12583659, and 12589161.
Rick
Any of these will work in my 99 Z28?
12576106 – 12570558 – 2003 G-VAN, LM7, ALSO C-TRUCK LM7
12586243 – 12583659 – 2004 GTO LS1
12589462 – 12589161 – 2005 G-VAN, LQ4
12602801 – 12589161 – 2006 – 2007 Express, Drive by Wire but has IAC drivers inside as well
https://ls1tech.com/forums/pcm-diagn...-write-up.html
It appeared that the P59 out of a 03 - 05 Truck/Van paired with a Hummer OS is pretty much plug and play into the F-Body, with the exception that you have to add a 10k omh resistor to the tachometer and also tune out the O2 Sensor Heaters, and it appears that members have had problems with TCS/ASR not working.
It appears that the more complex setup would be to upload a Tahoe tune onto a 0411 PCM as there have been reports of airbag lights on and service vehicle lights on due to BCM and PCM incompatibility. My car however is a 99 and not 98 so I might not have this problem?
I am still not clear however as the thread never solidified which P59 people are using in their F-Bodies although it did go into what they had to modify to get it to work.
It wasn't fully clear to me in previous threads is what specific P59 PCM's people are using in F-Bodies as it seems these PCM's vary widely.
Where can I learn more about xdf files and can they be used on my 9360361 OS?
edit-- It looks like there are also youtube tutorials explaining some of this. I should have thought of that first.
I bought a P59 PCM for my 1998 Pontiac Firebird LS3 Swap for flex fuel compatability. What year / make / model does the P59 PCM need to be configure for? A 2003 Truck / Van or a 1998 Pontiac Firebird 5.7?
