Narrow-band and wide-band disagree
Hello All,
Let me start this off by saying I am wearing my flame-proof undies... I am sure I will need them.
I have searched but not found a "process" to make\adjust my narrow-band O2s agree with the numbers I am seeing from my wide-band. My wide-band is just a few inches behind the Narrow-band.
I can tune my VE table with a wide-band, but as soon as I go back to closed-loop my fuel trim numbers are wrong by approximately 4% (compared to the open-loop wide-band #s).
--Is there a process or method to adjust\calibrate for this?
--OR... is this just the way it is and I should learn to live with it???
Let the flaming begin...
...any help appreciated!
2002 C5 ZO6
LG LTs
VaraCrap
224/228 114+4
2002 C5 ZO6
LG LTs
VaraCrap
224/228 114+4
"-Is there a process or method to adjust\calibrate for this?
You can change the O2 switching voltage by a few thousandths, see if that helps tame the OCD
If you plan to run in closed loop normally, then tune the closed loop areas with your narrowband fuel trims. The wideband is really only needed for your open loop power enrich areas. Unless they are just defective, the narrowbands are always more accurate at stoich than the wideband. As for making them match, that would depend on whether you are taking a direct serial out signal from the wideband or interpreting an analog out signal.
So I posted on 3 different forums...
... and I am getting the "...this just the way it is and I should learn to live with it" message from several posters.
Which is all good... I was just wondering if I was missing something and\or needed more research. Given how small this cam is, I really don't feel good screwing with the Narrow-band O2 switching voltages.
Again... thanks for the comments.
Working off the title of this thread, I have a question on the function process of a narrow band O2 sensor.
Aren't they basically a 3-position response sensor? As in Lean-Stoich-Rich, with no variations between the 3?
This is as opposed to a wide band that actually reads a sliding scale of AFR measurement.
Please educate me on this.
Do you have a gauge or just logging it in HPTuners?
edit-- A parabola was the wrong shape to reference, because obviously the voltage swings in 2 directions, and not the same way for both rich and lean, but the basic idea is the same. I have issues picturing things in my head.
Thank you VERY much! I'd always wondered about it, and you clarified it nicely!
I checked the for exhaust leaks to the best of my ability but Im still not a 100% sold that there isnt any. I mean, if there is I cant notice it. I got the collectors clamped with U bolt clamps and I also wrapped high heat tape around them. The Y pipe is old and the ends that slip over the header collector have been beat up a little from prying it off and on.
That Y pipe is looking like the culprit
I did a test today. I put the WB sensor into the header collector bung, and the Driver O2 sensor in the bung thats in my Y pipe. I started the car and The wideband reads right at Lambda, My STFTs read -25 +/- 3
With the WB in the bung thats in the Y pipe and the driver O2 in the header collector, the WB reads about 15% lean and the STFTs still read -25 +/-
When operating in closed-loop mode, your fuel trims can fluctuate within ±25%, yet the wideband oxygen sensor should still read 14.7 AFR. Additionally, the further downstream the wideband sensor is placed in the exhaust system, the less accurate its readings will be at idle or low throttle. In most cases, I find that factory narrowband O2 sensors provide more reliable data than a wideband sensor under these conditions and only use the WB for WOT.
I'm going to pull the Y pipe off and pressure test it to look for leaks.
if it checks out fine, then I dont know what to do.
I tuned my VE table to where the STFT were within 3% but then the WB read 15%-20% lean.
Your saying just ignore the WB at idle then?
If your fuel trims are +-3% at idle and part throttle I would ignore the wideband. Put it in OL and see what the wideband says...either way I trust the O2's more at idle over the wideband.
