FIXED! : Tach drops to 0 when accelerating
Just to confirm, you didn't convert this to a front cam gear/sensor cover setup did you? It's still just using the OEM position cam sensor in the rear top of the block correct?
Fuel gauge randomly dropping to empty indicates the PCM thinks something is wrong with the sender, that's default behavior when it throws a fuel tank level sender code. Lots of C5/C6 corvettes have this problem with their age now.
I'm not sure what else to try.
This all happened right after I installed the blower cam.
yesterday I removed the intake to recheck the cam sensor wire and the grounds on the back of the heads. Everything checked out perfect. The ground wires looked perfect. I scuffed the back side of the head down a little to make sure the surface was clean.
I ohm tested the cam sensor wires from the plug back to the PCM connector. All showed .000 ohms.
The red voltage wire showed 11 volts with the key on, engine off.
Today I swapped in a different gauge cluster. NO CHANGE.
Next step is to try another PCM.
Not sure what else to try at this point.
A buddy gave me oem cam sensor to try.
Also you said your buddy gave you an OEM cam sensor, what sensor is in it right now? Is it just the original OEM sensor?
I guess at this point it's worth trying a new PCM loaded with your current tune to see if that fixes it, but I've never seen a failure like this before and I've seen a LOT of these things over the last 20+ years. I would still lean towards something mechanical that has to do with the cam swap since that's when the issue started.
When I installed the cam, I planned on just lining the dots up. Did it before in the past never had a problem.
Well with the oil pump still on, that made it extremely hard to see the dot on the crank sprocket. However after getting my face inches from the sprocket, I believe I found it and got it lined up. That top picture you can see the dot from the cam sprocket and directly below it the dot or the "O" on the crank sprocket. I assumed this is Dot to Dot. Look at the Cloyes instruction sheet I attached and zoom in. You can see what I'm talking about.
Like I said, I bought this engine already built and If the shop that built it used a different keyway when putting the crank sprocket on, me lining the dots straight up could be screwjng things up.
This was the 1st thing I did when I started experiencing this tach issue.
I told my buddy about that ebay sensor I bought and he questioned how legit it was and he gave me a used, factory GM Ls1 cam sensor to try. Haven't tried it yet.
The start of the video is where I had it "dot to dot"
The end of the video is where the tooth labeled 2A is at TDC and this is where it needs to be since the machine shop used the 2A keyway slot when setting the crank sprocket.
