FIXED! : Tach drops to 0 when accelerating
Old Apr 15, 2025 | 06:31 AM
30th t/a's Avatar
Default FIXED! : Tach drops to 0 when accelerating
As the title says, the tach drops to 0 when I start to accelerate.
*this issue did not happen before the cam swap I just did.
*Happens around 3000 rpm. Once I let off, the tach starts reading just fine.
*HP tuners data log shows no issue with RPM. The rpm is logging the entire time.
*No other issues with the car, starts and runs good.
* Codes p0342 and p0343 are popping up
I performed a crank relearn procedure but that didnt help.
I know it could be a crank sensor or a cam sensor issue but I wanted to ask you guys for any other ideas.
Thanks
Old Apr 15, 2025 | 11:41 AM
mrvedit's Avatar
Moderator
Definitely not the cam sensor and I'm pretty sure any issue with the crank sensor would kill the engine or a least show RPM problems in the scanner.
I'm thinking just a loose wire going to the tach or in the tach itself. Maybe that new cam is giving you stronger acceleration than before and some marginal connection is coming apart.
Old Apr 16, 2025 | 05:02 AM
30th t/a's Avatar
Here is a video of the Tach loss
Old Apr 16, 2025 | 09:20 AM
ss1129's Avatar
Does the tach drop out if you are stationary and raise RPM or only while driving?
Old Apr 16, 2025 | 09:30 AM
30th t/a's Avatar
Good question. I'm not sure but I'll will give that a try.
Old Apr 16, 2025 | 10:31 AM
NicD's Avatar
7 Second Club
Tach is driven by the cam sensor. It's either the cam position sensor/wiring, the cam reluctor itself is wonky, or the cam is moving forward/backward in the block... and yes I've seen that before when the bolts loosen up.
Old Apr 16, 2025 | 04:40 PM
30th t/a's Avatar
Okay thank you! I'll will be investigating all of that.
Old Apr 22, 2025 | 02:38 PM
30th t/a's Avatar
It drops out stationary as well
Old Apr 22, 2025 | 02:51 PM
ss1129's Avatar
Does the RPM drop out on a scanner or only the dash?
Old Apr 23, 2025 | 07:39 AM
Old Buzzard's Avatar
"HP tuners data log shows no issue with RPM. The rpm is logging the entire time."
Old Apr 23, 2025 | 09:30 AM
ss1129's Avatar
That tells you its either cluster or harness related after the pcm.
Old Apr 23, 2025 | 09:46 AM
NicD's Avatar
7 Second Club
No it doesn't, the PCM uses the crank position sensor for engine RPM and that's it.
Old Apr 23, 2025 | 10:14 AM
ss1129's Avatar
But engine RPM doesnt drop out at the PCM. Its reading correctly on HP tuners at all times.
Old Apr 24, 2025 | 04:00 PM
30th t/a's Avatar
So far I've tried a new cam sensor, crank sensor and adding a resistor between the white tach wire and a 12v wire...nothing worked.
Yesterday I pulled the blower cam out set it next to the OEM Ls6 cam and it looks physically identical. The over length is exactly the same, and the cam reluctantors measure out exactly the same as well.
Spoke to a Comp Cam tech rep and he said if it was the new blower cam causing the issue, it would happen all through the rpm band. He said, in his opinion, I'd be waisting my money sending it back to them for inspection but if I wanted to, it would be $75 and 2-4 weeks turn around time.
I decided to put it back in the car.
Might look at the crank relearn procedure again because when performed it before, I never got a notification saying that "crank relearn was successful"
Old Apr 24, 2025 | 04:27 PM
ss1129's Avatar
Try a test PCM or cluster.
Old Apr 25, 2025 | 10:06 AM
30th t/a's Avatar
Thanks, I will give that a try.
Old Jul 14, 2025 | 03:13 PM
ss1129's Avatar
Did you ever get this sorted?
Old Aug 2, 2025 | 09:22 PM
30th t/a's Avatar
No I haven't. I put it on the back burner. I will be sure to update this thread once I get it figured out.
I fully believe it has something to do with the cam swap I did. I've read that I need to do a crank relearn because now the PCM thinks there's a miss fire and doing the crank relearn procedure with HP tuners is hit or miss and Ideally I should find someone with a Tech 2. I've also read and was told that it could be my IAC stepper motor. I just put a new one in today but didn't get a chance to test it out.
I found a few people on this site that had this exact issue. The one guy said after the crank relearn the issue was fixed. The other guys never replied to my PM.
Old Sep 26, 2025 | 11:18 AM
30th t/a's Avatar
I had the dealership look at my car for this issue. He used a Tech 2 and successfully did a crank relearn but that did not fix the issue.
He believes the issue is with the cluster or the PCM.
I am now getting the cam sensor codes p0342 and p0343 codes as well.He called it a class 2 communication issue and believes its either the cluster or the PCM.
Another thing, Occasionally My fuel gauge is randomly dropping to empty, triggering the "check gauges" light. I figured it was the float getting suck.
I wonder if this is related to the tach issue.
definitely going to be swapping in another cluster and if that doesnt work, going to try another PCM
Old Sep 26, 2025 | 11:39 AM
NicD's Avatar
7 Second Club
Those codes are kind of opposite each other so it's weird it's throwing both, circuit low and circuit high. Those codes are directly from the PCM thinking there is a problem with the cam position sensor/circuit, it's NOT a class 2 communication issue as it has nothing to do with it. The cluster is not the issue either. The tach signal comes from the PCM along with the other data over the class 2 databus and everything else is working just fine, and if there was a class 2 databus issue it still wouldn't throw those cam sensor codes.
Just to confirm, you didn't convert this to a front cam gear/sensor cover setup did you? It's still just using the OEM position cam sensor in the rear top of the block correct?
Fuel gauge randomly dropping to empty indicates the PCM thinks something is wrong with the sender, that's default behavior when it throws a fuel tank level sender code. Lots of C5/C6 corvettes have this problem with their age now.
