Accel Gen 7 Users Inside!
Last night I finally got to take a stock bottom end car to alleviate aftermarket crank and relucter wheel related out of the equation ..car spun to 7400 rpm with no issues not even a hiccup ...This car however is running ac delco wires and I'm beginning to think that the noise in the aftermarket wires may be a cause for some of the problems listed here...Anyway other than that the gen7 performed flawlessly..the post on how this car ran is in the drag racing section ..Hawkin01 is the author..
info on the car:
stock bottom as came from gm 346 ls1
5.3 heads coil packs in stock location and stock delco wires
custom hyd roller
fast intake w/90mm
kooks headers
gen7 dfi
th400/4.11 gear/ 28 " tire
fuel : 93 pump gas
car ran 4 consecutive times without any issues with a best of
10.37@129.9 mph N/A
JS, I know you have been posting about the problems with the Gen 7 system and how it will never work properly. Well I hope this was a good example of how it does work properly.
Mightymouse, I'm glad your problem was as simple as a new set of GM wires. It seems it is always the small things that will bite you in the ***.
TJ
TJ
Congrats on the times also Hawkn - car is running great.
So is ACCEL working with shops to get this fixed or are kits dusty on the shelf?
If I have a friend with a kit can he return it to ACCEL? I hope folks who bought the kit and plannned to spin their setups to 7500 are not left hanging... technically if you can't spin it up there it's not doing it's job.
ADMIN
The RPM never went above 7000 when it started breaking up. As you can see on a couple passes it even shuts off the injectors. Rev limiter is set at 7500 and fuel cut it set at 8000rpm. I'm hoping the wires will fix it, find out pretty soon since I cancelled my trip to florida because of the hurricane BS..Accel has been very helpfull and they want to get it fixed, we'll see what happens sunday with the stock wires..
You mean to tell me changing to stock GM spark plug wires would iliminate this problem? Or will this just cost me more needless spending.
I just read this post and I never knew there was a problem with the Accel system till now. Why didn't someone tell me.
I guess I'll be calling Accel on monday. I have talked to them before but they never said there was a problem with the system.
The only person I seen prevoiusly post about an Accel Gen7+ problem was JS and I just ignored it.
Sorry JS and thanks.
Tom, If there was a issue I knew of ,I would have told you..same as when allen called me and buster...best thing to do is call accel and hear it from them..since my word means nothing here.. since my name isnt Dale,John,or Dan..
Thank you
I may have magnecor build me a set of wires and try that (they are always bragging how they have the least RFI of any wires), or I may just buy some new brackets and cut them up but no matter what I do it will be a huge hassle changing plugs with where I will have to mount the coils for them to reach with stock wires..
