Crazy car driving me crazy!!!
Old Nov 7, 2025 | 01:30 PM
grinder11's Avatar
Anyone else ever had this happen? Ill tell you, it's a HUGE PITA when your traveling! I have to get up at 2:00 in the morning and go outside to start the car to warm it up for the next morning's drive....
Old Nov 7, 2025 | 03:39 PM
Tommy42088's Avatar
They is no way id deal with that everyday. Id be outside everyday after work or any free time I had trying everything I could to figure it out. I hate my vehicles to have issues.
Old Nov 9, 2025 | 09:16 AM
grinder11's Avatar
I have tried everything I can think of to deal with it. I'm not a tuner, and have no skills in that area. Obviously, this is a very unusual problem. I'm hoping for a knowledgeable tuner to chime in that has had this same problem. I believe it is a problem somewhere in the TB, MAF, or maybe the TAC. It SUCKS!! I'm almost 72 years old, and starting to look ahead to the point of someday selling it. I'd hate to see someone else struggle with it. If I sell it in the summer, buyer will be good until temps drop to under 67°. On the other hand, I have to do what I have to do. This is a Helluva corner I'm finding myself in, I'll tell you.....
Old Nov 9, 2025 | 09:43 AM
Looking back over the last few posts, I can't help but think it's still a poor connection somewhere.
I'm 73 and also would not need this sort of complication in my life! LOL!
Having said that, what all has been replaced so far? Just a quick list...
Old Nov 9, 2025 | 01:17 PM
Tommy42088's Avatar
didn't realize you were 72 now i understand, im 37 and id be turning wrenches till I was blue in the face until I figured it out. I just dont think its a tuning issue. I feel like you have a sensor failing you. You dont have anyone knowledgeable in your area that could come by and help you? I know by buddy who helps me with my truck could figure it out but we are in Louisiana.
Old Nov 11, 2025 | 03:27 PM
grinder11's Avatar
If only I knew wtf I was doing with tuning an EFI, I'd buy HPTuners, and with some help from some of you guys, I'd give a few things a try. I am real good with jetting carbs. Which is useless in this context. God knows it's cold enough right now in Florida. I'd have plenty of opportunities for <67° starts!!!!
Old Nov 11, 2025 | 04:12 PM
Tommy42088's Avatar
Man there alot of tuners in Florida! I worked in Tampa a few years back and every red light I stopped at there were turbo rides at the red light and dyno shops on the corners.
Old Nov 18, 2025 | 08:57 AM
grinder11's Avatar
Since it was brought up that my tune seems to have been based on this, can any of you explain why I would need a vacuum referenced fuel pressure regulator? Is this something a FI engine would need moreso than a NA engine would? I plan on calling my tuner on Thursday, and will report back what his response is.....
Old Nov 20, 2025 | 04:33 PM
grinder11's Avatar
OK, a couple of updates. Called Tuner. He was floored when I told him the injector data was incorrect. He says he remembers me telling him that I have 42lb OEM LS7 injectors. Why the file is referencing 36lb injectors, he doesn't know. Our best guess is the first 427 I had did use 36lb injectors, and it somehow carried over to the new tune. He is pretty sure he entered the 42lb spec. He says it's possible it didn't populate, or he remembered me giving him the 42lb data, but he could've been sidetracked somehow, and it never got entered. At any rate, the tune is based on 36lb, instead of the correct 42lb injectors. He agrees that everything in the tune would have had to be altered to compensate for the wrong injector size. I ran a couple of other things guys saw by him, and he agreed that some of the data was probably not able to be transferred/altered enough to compensate for the wrong size. He said he'll send me the cold start files, both over 67°, and under, when he can. He's taking a couple-three weeks off for a vacation and to work on his own stuff. So it may be awhile, maybe mid December, before I get any new info. I'll post it when I get it. A big THANK YOU VERY MUCH to everyone who has tried to help me out here. If it weren't for forum members, the incorrect data may have never been exposed. THANKS AGAIN, GUYS!!!
Old Nov 24, 2025 | 09:27 AM
grinder11's Avatar
Anyone???
Old Nov 24, 2025 | 03:58 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
So you can make either style work, but if you have a vacuum/boost referenced regulator, it makes the effective pressure drop across the injector always the same. This is more important with FI, because if you were to be running 30lbs of boost on a base fuel pressure of 45psi, then without a referenced regulator your effective fuel pressure across the injector would only be 15psi. Without FI the difference can only be a few psi anyway, so it is not as important. However, whichever style you have MUST be reflected in the injector data in the tune in order for things to work properly.
Old Nov 24, 2025 | 04:22 PM
  #32
Tommy42088's Avatar
Dont see where this would affect the 67 degree no start. Again I would trace down with heat/cold. I hope im wrong and you figure it out.
Old Nov 24, 2025 | 04:50 PM
  #33
gametech's Avatar
I'm not saying that has anything at all to do with his current issue. I was just answering a question he seemed to be interested in.
Old Nov 25, 2025 | 06:22 AM
  #34
Tommy42088's Avatar
I was responding to him because he seemed excited to find out the injector data was incorrect. A good find but im not fully convinced that wrong injector data could cause i can to not start under 67 degrees. Run bad? Yes , struggle to start? Yes, but only crank above 67 degrees? Hmm doesnt add up to me. I wish he was closer to me because id honestly like to see this is person, something has got to be shorting out, imo. Losing crank, rpm, something along that nature.
I would climb under it with a heat gun and put some heat on the crank position sensor and see what happens, next id get under the dash with a voltage meter and check the tdr. Id also check the ignition switch. Id say check the temperature sensor but id think it would still turn over if that causing a false cold to ecu. Long story short, heat and voltage meter would be my best friends on this.
Old Nov 25, 2025 | 07:07 AM
  #35
Tommy42088's Avatar
This is chat gpt answer
**A 2000 C5 Corvette that will not start below about 67°F and starts only when heat is applied to the front bumper is almost always caused by a failing Engine Coolant Temperature (ECT) sensor or damaged ECT wiring. On cold mornings the ECT sensor or its connector contracts and creates an open-circuit, making the PCM think the coolant temperature is –40°F. This triggers extreme cold-start enrichment, flooding the engine and causing the idle air control valve and throttle plate to slam shut as the PCM tries to stabilize the impossible mixture. Because the 2000 model uses a cable-driven throttle, the throttle closing is a mechanical reaction to over-fueling, not an electronic throttle fault. When you warm the front bumper, you are heating the ECT sensor area and wiring harness enough for the resistance to return to normal, the PCM gets a realistic temperature reading, and the car starts immediately. The fix is to replace the ECT sensor (located on the driver-side cylinder head under the throttle body) and inspect the connector and wiring for corrosion, cracked insulation, or broken conductors. The repair is quick and inexpensive and is the classic solution for C5 Corvettes that will not start in cold weather and only start when heat is applied to the front end.**
Old Nov 25, 2025 | 10:40 AM
  #36
RonSSNova's Avatar
Wow! Chat GPT nailed it!
Except the C5 is DBW…..
Old Nov 25, 2025 | 11:11 AM
  #37
grinder11's Avatar
It turns over/cranks at ANY TEMP. Under 67° it cranks, starts, runs for a half second, and stalls out. Tuner says something causes the butterfly to close completely, hence the stall. I ran the ECT sensor by the tuner, and he said he'd have seen some funky info coming from the ECT in his data logs, and saw nothing unusual, no red flags. So there's that. But it always cranks and starts. Over 68° it stays running, under 67-68° it starts immediately, and stalls immediately.....
Old Nov 25, 2025 | 11:17 AM
  #38
grinder11's Avatar
Thank you very much for the info. But I don't know if that info applies to Corvettes, because the C5 TB is drive by wire, NOT cable driven. I WILL say that when the throttle blade/butterfly closes, the motor is extremely rich!! Even when I give it a bit of pedal to get it running, it chugs like it has a stuck choke, which we know it can't have with no choke. But that is exactly what is happening. It closes the blade, and is immediately flooded........
Old Nov 25, 2025 | 11:26 AM
  #39
grinder11's Avatar
I'll also add that earlier this last summer, I had removed the alternator, and when I put it back on, it pivoted before I could get another bolt in it, and slammed against the bracket and valve cover. When this happened, I had the ECT sensor pigtail in the wrong place at the wrong time. The alternator nearly cut the pigtail thru. I had to pull the alternator again, and I stripped each end of the severely damaged wire, soldered them together, and used shrink tubing to protect the wiring. I know its fixed correctly, but when I tried to start the car before I knew the wiring was damaged, it was really rich, and one of, or both, the cooling fans came on.
Old Nov 25, 2025 | 11:33 AM
  #40
grinder11's Avatar
Yup, and has no IAC.....
