Crazy car driving me crazy!!!
The fact that you have NOT tried another ECT sensor yet seems to imply you really have no intrest in fixing the car, maybe because once its fixed you will have nothing to do?
The only thing I noted is that the IAT says 88 deg F and the coolant sensor says 72.
True cold start they should be within a few degrees of each other.
Ron
More convinced than ever it's in the tune. All this BS is SO FRUSTRATING!! Car runs so well at all speeds and rpm's, and starts immediately IF coolant is 68°-70°. DAMN!!!!
If it was 88, coolant would also be that temp (88).
Basically, whichever indicated temp is way out of line from ambient points to a bad sensor,
On a cold start EVERYTHING should be at or about ambient.
Not arguing, but things warm up quicker with that much temp change, especially aluminum compared to, say, iron.
