Line pressure vs kpa
Old Oct 21, 2025 | 07:07 AM
Tommy42088's Avatar
Default Line pressure vs kpa
For those who dont know my setup is a single cab silverado with a piston & rod gen 4 5.3 with vs racing next gen 2.5 78/75. I have a 4l60e that is built to handle the power levels i putting at it with a rossler transbrake. I was wondering what kind of line pressure you guys are putting to your transmissions? My line pressure in park stays around 150 psi and to me that seems a bit high. I tried raising duty cycle in holley and it had no effect on those numbers. My transmission does not give me any problems but i was just curious how you guys are dropping line pressure and could you share you setting with me. I have a 0-300 psi pressure sensor screwed in the npt port on the side on the case wired to holley terminator x max so im positive my readings are correct. Im measuring in dome pressure vs kpa since it turbo. My current setting are.
1st gear- 30, 30, 30, 20, 15
2nd gear- 30, 30, 30, 20, 10
3rd gear- 30, 30, 30, 20, 10
​4th gear, 30, 30, 30, 20, 10
Old Oct 21, 2025 | 01:09 PM
Tommy42088's Avatar
Anyone?
Old Oct 21, 2025 | 01:46 PM
91 Z28's Avatar
On my 4l80e my line pressure is 24, 24, 24,16, 0 And I believe I'm also around 120-130 psi in park and 195-200ish at WOT
Old Oct 21, 2025 | 02:17 PM
Tommy42088's Avatar
damn your pressure is set a little higher then mine and your psi is lower. Do you have a turbo and what temps were your transmission when you checked it? My trans temp was around 130.
Old Oct 21, 2025 | 02:19 PM
91 Z28's Avatar
Yep I've got an 88mm turbo and I run a big remote transmission cooler my temps on a hot summer day after usually in the sweet spot of 165-175. Your 130* temps is too cold
Old Oct 21, 2025 | 03:44 PM
Tommy42088's Avatar
I checked this last night and even though I live in Louisiana is was fairly cool last night and I have a Tru Cool 40k transcooler with dual fans. I let it run about 20 minutes in the driveway but thats about where the temps stayed. It will go up more if I were to go drive it but I still figured whether it was cool or not that my line pressure still should have been around the same. I could understand a few psi but was at 150 and I was hoping to see atleast 120 at idle and i wouldn't expect driving it that it would go down 30+ psi.
Old Oct 21, 2025 | 05:24 PM
91 Z28's Avatar
The Holley systems have temperature based modifiers that cut things down when fluid temps are colder. You can change those parameters as well. If your line pressures are up high then most likely it's the spring installed in the pump
Old Oct 21, 2025 | 05:41 PM
Tommy42088's Avatar
10-4 this forum can be closed, I got the information I needed from the builder.
