need help with MAF tuning
Im trying to get my junk dialed in but having some questions about the MAF tune Im doing. Im a noob as far as engine tuning goes but very excited about learning this.
The setup: LQ4 with 862 heads and Elgin 1838P cam, flex injectors 12594512, long tube headers, manual trans.
Since this cam is very similar to the Z06 cam and trying to get a jumpstart, I copied over the VE table from a 2004 Z06 and the graph seemed to make sense.
On the first run, it was lean everywhere, so I added 15% airflow across the board on the MAF table, the weird thing is that it goes above the limit by the end of the scale, but since its just a couple cells, fine.
After a few runs and adding even more air on sections of the MAF table, I noticed that the higher I go, the leaner still is, making the end of the scale be maxed out for more and more cells. I'm sure this cant be right but I'm stuck. I have already double checked the injector data.
Im posting the last run log and the hpt file of my setup, I have made a few small changes to the hpt tune before the log but the issue should still be visible.
Was using the Z06 VE table a bad call and should I start over with the truck table? Should I just try tuning for speed density instead?
Maybe try again using the corvette VE table +5.2631%? (adding volume as displacement difference 5.7 to 6.0)? The problem with this is that some cells go above 100 VE, which Im unsure would make sense on a NA.
I was having an entirely different issue with the narrowbands as well, they would not get a proper ground from the PCM to heat up (PCM is a 2005/P59), they would start working somwhat ok only after the engine was well warmed up. The engine was pretty warm in this run.
Any chance I could have set it up wrong?
I am going to hotwire the ground on the o2's and get new readings today. I also had a vacuum leak by the throttle body gasket before and thought it was sorted, but will check that again to discard this possibility.
note: My wideband is on bank 2.
Looking at the last, does it seem like I might have a fueling issue between banks aswell?
The engine seems to run smoother with this leaned out file compared to before, rpms would dip on return to idle quite a bit before, I thought it could be due to the scaling of the MAF table, as I was adjusting cells individually trying to match the lean/rich indicated by the wideband.
I reenabled all trims and others settings i had turned off, DFCO, etc. Tune file is using the Z06 MAF(and Z06 VE) + 5.23% across the board.
first file is driving right after the change, second file after stopping, shutting engine off and back on, then driving back.
how can I tune for trims? disable LTFT and adjust basing on the logs STFT ?
Not sure if you looked, but Im starting to suspect maybe theres an issue with my injector settings, particularly pulse width, as its not keeping up with higher rpm or fast changes in rpm. I found two different settings for Flex injectors, one from a spreadsheet that somebody put together and another with data I extracted from P59 PCMs with flex injectors (but I think these cars came with a different injector part #). and used what the spreadsheet said it was for the 12594512, dont recall if I ran with the other settings.
Wideband still reads lean 15AFR and up at all times basically.
I just recalled my wideband is installed on the exhaust right after the long rube headers junction to the Y pipe, so there might be air leaking in from that junction, I will look into ways to better seal it.
I have tried the tune looking at LTFT+STFT but I ended up running rich, lots of exhaust smell too especially with the trims enabled. I swapped the stock o2 with the wideband (bank 2, the wideband was after a exhaust junction and the stock o2 was right at the long tube headers). There is a noticeable difference in readings, so probably getting air in the junction, messing with the readings.
I did a couple of runs and retuned the MAF, smell seems better and readings look more consistent but still going off the chart at the end of the MAF if you extrapolate the 15%+ air it asks for. Note: Long tube headers end is 3in and the y-pipe is 2x 2.5in junction to a 3in.
Quick question, do the stock o2 readings on bank 1 look ok to you based on the new wideband readings? b1 and b2 now differ quite a bit as the b2 is installed after a junction that seems to be letting air in.
