High IAT - Pull Timing or Add Fuel?? Or Both??
Old Dec 19, 2025 | 08:10 AM
91 Z28's Avatar
Default High IAT - Pull Timing or Add Fuel?? Or Both??
Hey guys what's the consensus with higher IAT temps (150+) in regards to pull timing or add fuel?? Is one better than the other?? Just curious what y'all think cause this has come up a bunch for me the last little while. The internet is drastically different from one to the other. Thanks guys have fun!
Old Dec 20, 2025 | 10:10 AM
LS1Formulation's Avatar
Honestly, I'd add fuel over dropping timing. Additional fuel will always have a cooling effect. Timing will kill power, but I don't see it necessarily reducing coolant temps that much. Plus with retarded timing, it puts a lot of heat into the exhaust, which is going to heat up your engine bay and make the high IATs worse. I'm assuming your IAT sensor is before your meth nozzle? I'd be curious what the temps would be like post meth nozzle. Any way to add another IAT sensor for monitoring?
Old Dec 20, 2025 | 10:25 AM
91 Z28's Avatar
I have 2 1/8" bungs about 20" away from the TB where my meth nozzles used to be. I could always drill it out and tap it for another IAT sensor. My rife IAT is just before the TB blade. I also have a spot under the intake manifold where I could install a sensor
Attached Thumbnails High IAT - Pull Timing or Add Fuel?? Or Both??-pxl_20251219_184109590.jpg
Old Dec 20, 2025 | 01:44 PM
Full Power's Avatar
Aftercooler..
and/or add a second meth nozzle, pour more water on it.
Old Dec 20, 2025 | 02:34 PM
You say where the meth nozzles used to be - Does that mean you're not using them now, or are they post TB now?
Old Dec 20, 2025 | 03:22 PM
Full Power's Avatar
Photo shows a right angle nozzle holder pass side couple inches forward of throttle body. I'd add another spray nozzle further out on opposite side.
My 5.3L @ 190kPa won't take much timing on local best available (90 octane) pump gasoline, 9 degrees from 4000 to 4400 rpm and up to 13 degrees spark above 4800 rpm.
Old Dec 21, 2025 | 10:14 AM
91 Z28's Avatar
There's a second nozzle right across out of sight from the first nozzle. With the IAT just before the throttle body
Old Dec 21, 2025 | 11:47 AM
How big is your intercooler? Have you ever logged temps before and after to see how efficient it is?
Old Dec 21, 2025 | 11:57 AM
91 Z28's Avatar
The intercooler is a 31x12 4" thick Mishimoto R line. I did take the car out yesterday for a rip but wasn't bothering with any logging it was just a cruise with some buddies. In the spring be doing some wiring so I'll get another IAT in there and I've got a pressure sensor for the water meth system I'm gonna send to the Dominator to monitor that as well
Old Dec 22, 2025 | 01:20 PM
NicD's Avatar
7 Second Club
Pulling timing as intake air temps rise is the standard way of doing things, the OEMs do it that way and every computer out there has a table to do it that way. Some add fuel if it hits a certain threshold ie intercooler pump failed and temps skyrocket, but primary function is timing retard.
Old Dec 22, 2025 | 03:12 PM
91 Z28's Avatar
I moved my nozzles up closer to the TB but after my BOV. I have two bungs lower in the piping that's plugged off
Old Dec 22, 2025 | 03:14 PM
91 Z28's Avatar
Excellent thanks Nic! I'm just trying to wrap my head around why some guys swear to just dump fuel when things get hot vs pull timing like OEM's do
