Need HP Tuner Help with Hot and Cold Start
Now I have a couple of questions to try to fix my cold and hot Start.What do I mess with ?The Idle Air Flow Vs.ECT(What is ECT?)IAC Park Position Air Flow Vs. IAT which do I play with?Also what is the IAC Reset Park ?Mine is set at 320...Please Help me
TIA
Scott
This will reduce the fuel on start up.
Save file and upload it!
Save the file (call it something different) and then upload.
I would recommend hitting the VE table slower
(more incrementally). The degree to which it
needs modified, depends a lot on the cam you
have (its overlap mainly I think). If you only
needed to shave, say, 15% off the volumetric
efficiency to represent it, multiplying by 0.7
right off the bat would put you as far wrong as
before, only to the lean side.
So maybe try multiplying those columns by 0.9,
try it & note any change, tomorrow try another
0.9 scaling (0.81x total), ... and be sure you
have shotgunned the space enough to find the
sweet spot. Don't want to step right over it.
IAC airflow vs ECT is a way to set the idle
"floor" just like the old fast idle cam on your
carb choke linkage. If you have a cold (or
hot) "crashing" problem I guess this can be
a backstop for you (it might override the
RPM setting or fight with it, dunno about
who wins). That kind of detail the HPTuners
gurus would have to give you....
If you really have a TR 224 cam, I'd do 70 75 80.... Any change you make will help!
I have the MTI X1 Cam...Thanks again...Scott
Scott
Scott, what mutipliers did you use for the load that you have in the car now? If hot and cold starts are fine, then your good to go! But if it still gives you trouble you might have to tweak it some more. You might also want to adjust the IAC table a bit too.
By making these changes, it will not affect your WOT dyno tune at all. With that came I'd set your idle to 850.
I'm just glad I could help you out on this. Over a year ago, it seemed this easy fix was a big secret...
,I have used .9=2 times now warn start is Much Better now,But cold start is still crappy
How low can I go with these numbers?Where do I put the 70 70 70 if I go that route?What does the Lower number in the 400 800 and 1200 mean?Is the Lower the Number more air and less fuel?I Dunno Thanks Billiumss
Scott
Does it look like this:
32 32 33
34 41 43
40 45 49
41 47 51
43 49 52
44 50 53
46 51 54
47 52 54
48 53 56
47 54 57
48 54 58
48 54 59
49 54 60
50 55 61
51 57 61
52 59 63
53 61 65
56 63 67
56 63 67
If you mutiply it by .7 from the stock Main VE, it should look like this:
27 28 29
29 35 37
34 39 42
36 41 44
37 42 45
38 43 46
40 44 47
41 45 47
41 46 48
41 47 49
41 47 50
41 47 51
42 47 52
43 48 53
44 49 53
45 51 55
46 53 56
48 55 57
48 55 57
Did you drill out you TB hole any? Have you adjusted your IAC Tables?
If you want, email me your file. If you do it within the next 45 minutes, I'll tweak it tonight and send it back to ya for you to try out.
Bill
32 32 33
34 41 43
40 45 49
41 47 51
43 49 52
44 50 53
46 51 54
47 52 54
48 53 56
47 54 57
48 54 58
48 54 59
49 54 60
50 55 61
51 57 61
52 59 63
53 61 65
56 63 67
56 63 67
27 28 29
29 35 37
34 39 42
36 41 44
37 42 45
38 43 46
40 44 47
41 45 47
41 46 48
41 47 49
41 47 50
41 47 51
42 47 52
43 48 53
44 49 53
45 51 55
46 53 56
48 55 57
48 55 57
Bill
Scott
