Help What Is Making Me Go Though O2 Senors?
#41
speaking of band clamps and having a piece of my pacesetter ripped off at a car wash, where do you recommend to get something that holds the pipes together better than those cheapo clamps that scrape/drag/rip off ? I was tempted to make some skid plates for the headers and tack weld them on if i didnt find a solution.
How does that RTV hold up to those EGT's?
#42
I think you’re thinking of the cheap band clamps, I’m talking about the $10+ each clamp that looks like this
You can get these from ls1speed.com or you can get them at most local Napa’s. These clamps seal very well the best really... once you see them you will understand. Also get them very very tight they take the shape of the exhaust and should make a 100% seal. If I get time tonight I will take a picture of mine and post it. Someone else might have a picture ready to go.
Also you might be able to make the gaskets for the AIR system by cutting your own... I did mine this way.
#43
Originally Posted by equandt
I installed the bosch 13111 and cleared the P1133 code from my car. I drove the car the rest of the day with no problems.
The next day, 3 minutes after start up, I threw another code.
I drove the car 250 miles yesterday. The SES light stayed on for 120 miles, then went off. The light has been off for 130 miles now.
I checked for exhaust leaks and found none. Everything is sealed up well. The car got 26 mpg on the trip (two lane highway).
#45
Another update:
