TRex Idle Tuning On A4
You don't really need to change anything for it to idle correctly as mine fired up perfect and find the idle almost instantly with the stock tune. I drove it for a week or so like that with no problems other than surging at low rpm's. Now with your Automatic the surging will be amplified as I could downshift or press the clutch in to keep it from surging until I got it tuned correctly on my wideband. The problem you will have is getting rid of the cam surge on an Automatic @ Low RPM's.
Ive heard of alot of people fouling out plugs extreemly fast with that cam. Do you run this car as your daily driver?
Ive heard of alot of people fouling out plugs extreemly fast with that cam. Do you run this car as your daily driver?It runs pretty decent on a stock tune with an M6. It does lope a bit more aggressive with the stock tune as the IAC tables and Idle RPM are set pretty low for the stock cam. I bumped my idle up to 900 RPM and increased the IAC tables just to make it easier to drive in traffic. As far as driving it I probably drive in some of the worst traffic anywhere. It takes me up to 1 hour 45 minutes to go 35 miles to work down 85. I live up in Duluth and drive down near the airport everyday. It is like a parking lot most of the time. I drove it to work like this for about a week until I got my wideband so I could start adjusting things.
