question: if you descreen your maf, should you change the MAF airflow table?
technically, it should be letting more air in, correct? so does that mean i should scale the table with hptuners? i did a search and couldnt find anything on this topic so bare with me here guys, because im a noob to tuning. thanks for any help!
It doesn't matter whether more air is let in, as long
as the frequency properly responds to it.
I found no measurable difference between two 85mm
MAFs, in the same air duct, screened and descreened.
At least, not anything I could pick out of the frequency
random variation.
If you care to, simply record all of your current LTFTs
by cell, pop the screen, and in a week or so check how
much they have drifted (meanwhile refraining from
messing other things around). Then, scale the MAF
table if you must.
random variation.
table if you must.
