Desired Shift Time
Old Aug 30, 2004 | 03:18 PM
Bill Bowling's Avatar
Default Desired Shift Time
Should I change the Desired Shift Time in LS1Edit after a TCI SSF3599 TC? I have increased line pressure and removed TM. What should I change the table to? Has anyone changed this table?
Bill
Old Aug 30, 2004 | 03:48 PM
deezel's Avatar
I have mine zeroed out with stock 'verter and shift kit. Shifts pretty firm.
Old Aug 30, 2004 | 07:38 PM
jimmyblue's Avatar
Moderator
I have run mine as low as zeroes, but currently leave
it at 0.150. My philospohy here is to get the shift
feeling solid but if it's good enough to suit then leave
it the slack. If you tell it zero it has to give full line
(PWM) on shifts regardless of whether it makes the
shift any faster or not.
Predator full negative "-25%" actually zeroes this table.
Never mind the math.
