IAT question...ECU use F or C????
Old Sep 21, 2004 | 02:48 PM
Phil99vette's Avatar
7 Second Club
Default IAT question...ECU use F or C????
I made up a resistor IAT to use when on the bottle. My autotap shows a constant temperature of 106F and that converts over to 41C. What does the ECU use? F or C?
Phillip
Old Sep 21, 2004 | 02:50 PM
GPowrie's Avatar
ECM is in C but at that temp with a stock IAT table that will pull 1 degree.
Old Sep 21, 2004 | 03:01 PM
7 Second Club
Does the 106(f) on auto tap convert over to 41 or 106 in the PCM?
Old Sep 21, 2004 | 03:50 PM
jimmyblue's Avatar
Moderator
Actually I think the PCM uses a one- or two-byte binary
value, not necessarily either unit basis, and the editor /
logger tools translate it to degC/degF purely for your
convenience.
Old Sep 22, 2004 | 07:18 AM
gameover's Avatar
internal PCM value is in C as is the data value that comes in the PID for the scanner. Scanners convert the C value to F.
