Big problem with my Predator
Old Sep 22, 2004 | 06:47 PM
99Andrew's Avatar
Unhappy Big problem with my Predator
My Predator has been sitting in my glovebox for 6 months or so. Anyway, I was experiencing some pinging on the highway (when floored). So, I plugged the Predator in to check the live knock data. When I plugged it in, the backlit light came on, but there was nothing on the display. Zero, nothing at all. Just a light with no information. Any ideas?...Thanks!
Old Sep 23, 2004 | 01:40 PM
RAMPANT's Avatar
I had the same problem. On the back there is a hollow looking hole at the back of the display. Get a jewellers slot screw driver and there is a contrast adjustment screw in there. Tinker with it and you should be back on track.
I freaked when mine did that too.
I hope this helps.
Rampant
Old Sep 24, 2004 | 02:38 PM
99Andrew's Avatar
I hope this helps.
Rampant
Thank you for your response. I'll try that today and see if it works!
Old Sep 26, 2004 | 12:31 PM
99Andrew's Avatar
Default No go!
Well, I adjusted the contrast screw on the back and had no luck. When turned either way, all of the pixels lit up or nothing was displayed. Again, no information was displayed. I've had this unit for 2 years. So, I assume the warranty is expired. Where is the best place to have this thing fixed? I'm not even sure if it would be worthwhile to have it fixed. Thank you in advance.
Old Sep 26, 2004 | 04:37 PM
GM Muscle's Avatar
Similar thing happened to mine. Contact Brian@diablosport.com . They replaced mine under warrantee even though it was a year and half old.
andrew
Old Sep 29, 2004 | 01:39 PM
Dano 00TA's Avatar
According to runningwiththedevil.com it has a lifetime warranty, so you should be able to get it fixed.
Old Sep 29, 2004 | 02:08 PM
99Andrew's Avatar
Default Thanks!
Thank you for your responses. I'll contact the company. When it's fixed, I'll let you know how it goes.
