normal misfire on 2 and 3 cylinder after new engine install
![Angry](https://ls1tech.com/forums/images/icons/icon8.gif)
I installed a 409 cast iron block engine in my 2002 camaro. I am trying to tune it but keep showing misfires on #2 and #3 cylinders. I edited the low rpm and idle misfire tables in ls1 edit (made all values 32000). The vehicle seems to run ok. I was told this misfire reading was normal and can be edited out. I am also running richer on one bank. Can this really be edited out, or should I be looking elsewhere? I already checked the spark plugs and the fuel injectors.
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Random misfires are normal. Concentrated misfires
are not normal. Though big cam, small converter,
etc. can elevate the counts. I'd say look at the
misfire count "noise floor" (log all 8 misfire current
PIDs, look at the min/max/avg values in Excel, and
see what "normal" is for this motor and whether
#2 and #3 are more than (say) 50% higher than the
rest. If so I would keep chasing mechanical causes.
If it's only a matter of degree I would set the misfire
threshold to something comfortably above the norm
but not the 32000 or 32767 "go away, boy!" value.
Just so you get warned about anything turning worse.
