Ve table question
Old Sep 29, 2004 | 01:49 PM
HumpinSS's Avatar
Default Ve table question
is it a 1:1 realtionship or 4:1 or what is the realtionship period.
Does 1 ve movement = 1 trim% or does 4 ve movements =1 trim % and how muc movement can you move before seeing a change in WOT AFR
Old Sep 29, 2004 | 02:22 PM
Bink's Avatar
Depends on if you are MAF or MAFLESS. Both answers are in gameover's thread ->http://www.hptuners.com/forum/YaBB.p...num=1078851555
joel
Old Sep 29, 2004 | 02:41 PM
HumpinSS's Avatar
MAFLESS :woot: how have ya been Bink
Old Sep 29, 2004 | 05:05 PM
jimmyblue's Avatar
Moderator
In my case ('02, MAF, rejiggered FTC boundaries) I
saw 1:1ish movement on the LTFTs - scaling VE by
1.02 gives a -2 LTFT drift. Which is sensible. Where
you have the MAF and SD airflow measurements
"blending", there the VE change will be attenuated
I believe - for example if it were a straight average
you would have to move VE twice as much to see
the same effect (as the MAF didn't move at all).
Old Sep 29, 2004 | 06:12 PM
Bink's Avatar
Good, thanks HumpinSS.
Trying to focus on work - less on the car. I'm very glad MAFLESS is going well for you - it's great to see you guys push the envelope ( we both know I didn't have much hope for your MAFLESS endeavors)!!!
Keep up the great work!!
joel
Old Sep 29, 2004 | 06:36 PM
HumpinSS's Avatar
the mafless tune is comming together the car drives and ehaves like a stock car just will a little more lope and volume. I still cant tunr the ac on without the car hunting but i guess you cant have it all aside from that i am very happy with the way it runs now...
