Knock sensors flooded w/ H20
I was throwing codes like a bitch and my tech-o-meter was busted.
Upon ripping the intake off, I noticed the top of the rear knock sensor was wet. When I took the knock sensor cable off I noticed the entire sensor was under water. Apparently, every time I went through a car wash or drove in the rain the water went under the intake, over the valley cover and right into the kncok sensor holes. I'm sure this had been happening for a long time since the sensor was corroided from the water.
1. I removed the LS6 valley cover, replaced it with a new one. I used high-temp silicone on the black cable plugs to ensure the sesnsors remain dry.
2. I checked the resistence of the cable - OK
3. Replaced the cam sensor, and MAP sensor
4. took the sponge off the back of the LS6 intake and reassembled unit
It has been running fine for two days now with no check engine lights. Even my tech-o-meter works great...
I suppose we can add this problem to the growing list of GM defects that we Gen 3 owners love about our cars.... So far I can think of these:
1. bad oil pumps that go dead often
2. rings and pistons that slap
3. rocker arms that spill their needle bearings
4. push rods that bend like my elbow
5. lifters that collaspe
6. flooding knock sensor caves
Remember this - next time - do not buy a GM hot rod!
Yeah, but in spite of all of that, we STILL love these things!
And the knock sensor issue is a known issue, one that GM will fix for free if you take it into them. They do just what you did....replace, dry, & silicone.
Originally Posted by patSS/00
Not at all - rockauto.com has them for $34.
BS!!!!! I KNEW IT!!!!
I took it to my local chevy dealer last time there was a knock sensor problem on my car and the service writer was fighting with me...I threw the knock sensor code, had my friend Jeff replace em and throw the LS6 manifold on there, I wasn't present for the install but he said they were COVERED in oil....I'm sure water is getting in there too....maybe I should stop cleaning my engine...
Originally Posted by robertbartsch
Has anyone else had the wet knock sensor problem?
Thanks,,,
Thanks,,,
What's cool about these cars is that once you get these issues solved, you got a kickass muscle car.
This is beside the point, but I had a lot of engine noise before my cam install, and after changing the springs, pushrods, and retorquing the header bolts, the engine sounds tight as hell. You can hear the valvetrain working like a sewing machine, but it sounds tight and healthy.
I love the heck out of my car after making up for GMs deficiencies. It's DEFINITELY worth it.
Long live the GREAT f-body!!!!
yes I would love this TSB number also...
the dealer fought with me telling me it wasn't an issue and just to fork over the 500 dollar labor charge...I believed them and had a friend replace the sensors about 5-6 months ago....I am REALLY ticked off now because it's throwing codes again
