VE Calculator
Old 10-28-2004, 05:42 AM
  #41
J&JsTA's Avatar
Originally Posted by HC02SS
When I get it, I'll host it up in this thread for people to DL if that is ok?
HC02SS....... all attempts to me have failed so far... either because of the ISP/outlook *.exe block or size
Old 10-28-2004, 08:02 AM
  #42
itchygomey98's Avatar
Absolutely, host it up.
Old 10-28-2004, 04:31 PM
  #43
Black02SS's Avatar
Here you go guys!!
http://home.insightbb.com/~xtinct/VEC.zip
Old 10-28-2004, 06:17 PM
  #44
J&JsTA's Avatar
You SIR ....are the CaTs @ss .... :thumbup:
... now....does it work
Old 10-28-2004, 08:40 PM
  #45
JimMueller's Avatar
Thanks!
It looks like you have a label incorrect. I believe it's IAT(Intake Air Temp in ºC), not IAC (idle air control) you want for your current formula. It also assumes you're using a 346ci motor.
So you right-click on the cells, choose edit/open, import the data into excel, choose file:Update and then exit Excel and it puts it in the old window. What can I do with it from there? Will it build a sample VE table based upon the results?
Old 10-28-2004, 10:48 PM
  #46
Black02SS's Avatar
Thank you!! It worked on mine so far. Let me know Joe.
Old 11-03-2004, 11:47 AM
  #47
Appafella's Avatar
Default I'd like to check out the VE calculator
This link is down. Could you send me the VE calculator? I'd like to begin playing with the VE table. Thanks.
Old 11-03-2004, 11:57 AM
  #48
Checkmate's Avatar
The link is down, any chance someone could host it???
Old 11-03-2004, 12:33 PM
  #49
rx7xj's Avatar
Link is down
Old 11-03-2004, 03:43 PM
  #50
Black02SS's Avatar
Working now.
Old 11-04-2004, 01:43 PM
  #51
rx7xj's Avatar
Yeah link works now. Can't seem to make any sense of the results though. Not sure if I am using correct input data. Anyone care to post up some sample lines of data and explain what to do with the VE output value.
I used MAP, IAT, RPM and gm/sec logged using LS1 scan but get calculated VE values around 2E-11 to 9E-11
Old 11-06-2004, 12:46 PM
  #52
Appafella's Avatar
Default Interperting data
Anyone with some ideas of what to do with the results? This is the first time I begin toying with the VE table. I'm tring to find a good way to tune LTFT. I've already tuned the IFR now trying to concentrate on certain areas.
Old 03-02-2011, 01:47 PM
  #53
ZexGX's Avatar
Did anything ever become of this?? Final version? Integration into an existing tuning product??
Old 03-02-2011, 01:55 PM
  #54
LS1TECH Sponsor
foff667's Avatar
Theres no point, just tune the ve rather than plopping in a "calculated" what "should" work figure.
Tuning has come a LOOOOONG way in the 7 years since this thread was started
Old 03-02-2011, 02:49 PM
  #55
ZexGX's Avatar
Thanks. Still learning about this sort of stuff, and that was exactly the answer I was looking for.
Old 03-02-2011, 08:44 PM
  #56
joecar's Avatar
With the modern tools the VE can be calculated from the corrected MAF log...
i.e. the MAF can be corrected and the VE calculated from a single log.
It becomes a choice of which is easier to accomplish, directly correct the VE, or calculate it from the corrected MAF.
It does require correct dynamic air temperature modeling, meaning in most cases it is just easier to directly correct the VE.
Quick Reply: VE Calculator
