Guys I used HP Tuners and this is what I got
Old 11-04-2004, 07:26 AM
UAE_77's Avatar
Default Guys I used HP Tuners and this is what I got
Guys,
I would like to know what my car read and what does the number refaring to. I read too many things but still it is vagefor me. Please help I will put the tables my car read.(Holden Cammador 2000 A4 with CAM, Headrs, ASP Pully,K&N Filter)
The Advance table:
http://www.geocities.com/ali_alqaedi/Advance_UAE77.JPG
The Retaed
http://www.geocities.com/ali_alqaedi/Retard_UAE77.JPG
The LT FT
http://www.geocities.com/ali_alqaedi/LTFT_UAE77.JPG
The ST FT
http://www.geocities.com/ali_alqaedi/STFT_UAE77.JPG
The Air/Fuel
http://www.geocities.com/ali_alqaedi/Air-Fuel_UAE77.JPG
Guys Please help...I'm trying to fix engine shake.
Thanks very much.
Old 11-05-2004, 05:59 AM
PREDATOR-Z's Avatar
You are in UAE. I'm in DUBAI, we should meet and compare notes.
Old 11-05-2004, 01:26 PM
my2kTA's Avatar
engine shake may just be the lope of your cam.
Im not sure how your timing table should look since i had some one else do mine.
retard - you want to get that whole table to be all 0s. Do this by removing as many degrees of timing as you have knock for that area. ie 2* from 1.8x.44, 2* from 2.0x.44, 1* from 1.8x.48
ltfts - all looks great in there. your car is running exactly where it needs to be. + numbers (red) are lean, - are rich (green)
stfts - never really care about these, since they just keep your ltfts in check. if they stft stays consistent it will load that as the ltft and then will start checking again.
a/f - im not sure how the narrowband info converts, but since your ltfts are in line, i dont think you need to mess with them.
Old 11-05-2004, 03:07 PM
P Mack's Avatar
I think it's a little suspicious that your ltrims and strims are all 0. Did you log in open loop, or is your tune just ridiculously perfect?
Old 11-05-2004, 03:30 PM
my2kTA's Avatar
if i would have looked @ the table i would have noticed that too
have you changed any of the default logging parameters? (shows in the table display of the logger). sometimes if you change it, it will cause your data to log incorrectly.
Old 11-05-2004, 05:57 PM
Another_User's Avatar
Well...I hate to say it, but all his actual AF ratios look perfect too. Other than crappy timing his fueling looks disturbingly perfect. But that AF ratio...it brings a tear to my eye....I wish I could get mine to do that. That car could not have been tuned by human hands...
Old 11-05-2004, 06:00 PM
Aha...I just realized something. No PE on that. Imagine how lean he would be at WOT...
Old 11-05-2004, 06:01 PM
Worm's Avatar
Isn't narrowband inaccurate for A/F?
Old 11-05-2004, 06:44 PM
P Mack's Avatar
It's almost like the o2's aren't operating at all and it's just reading the bias voltage of 450 mv.
Yes, but they're accurate enough to tell that there's no power enrichment going on at 450 mv.
Old 11-05-2004, 06:50 PM
I just thought something totally stupid, but....do you have O2 simulators? Like...what would they read if they were plugged into the front O2 plugs. Anyways, that vehicle is completely in limp mode (in more than one way), it has to be.
Old 11-08-2004, 09:18 AM
GuitsBoy's Avatar
This is exactly what I was gonna write. There's no way that his A:F is actually right there. however it's still suspicious that the sins would even be that perfect, as theyre supposed to generate a random voltage centered around 450 mV, no? Even with o2 sims, you should have some STFT movement. I dont know what could cause this, but I bet you disabled something. Check in with the hptuners guys on their forum, as theyll probably be more familliar with your holden.
Old 11-08-2004, 09:58 AM
currentman's Avatar
if this is an early model commodore, then it came from the factory with no cat's and no o2's, and will run in open loop.
what problems are you having specifically uae ?
Please post what you having trouble with and I will do my best to help you.
to tune your car properly, you will need the use of a wideband to moniter your air/fuel ratio's.
send me your bin file
