Cold weather Start with HP Tuners.
Old Nov 11, 2004 | 05:09 PM
Pro Mouse's Avatar
Question Cold weather Start with HP Tuners.
Ok here is the scoop,The car starts fine in 50 degree weather,but in 30 degree weather the car starts fine but when I take off it falls on its face(Chugging).But once it warms a couple of minutes its ok?What to fix,VE Table?
Thanks
Old Nov 11, 2004 | 05:41 PM
jimmyblue's Avatar
Moderator
Check out your idle MAP and ECT values cold, then go
to the Open Loop Fuel/Air table at the place those
indicate; probably see very high enrichment values.
Shave these back, for MAP cells at and below your
idle MAP value, by maybe -0.1 at a time and see
what the car really likes at that temp, how un-rich
you can take it before you get ping at light throttle
in open loop, etc. Don't send anything below 1.00
but the >1.3 fuel air multipliers in there from stock,
are kind of silly. Factory just didn't figure on people
idling at MAPs of 60, 80kPa.
Here's the OLFA table I stopped at (not to say it's
ideal, just "good enough to quit messing") for a big
cam car:
1.67 1.48 1.3 1.15 1.1 1.08 1.06 1.05 1.04 1.03 1.02 1.01 1 1 1 1 1 1 1
1.69 1.49 1.31 1.16 1.11 1.09 1.07 1.06 1.05 1.04 1.03 1.02 1.01 1.01 1.01 1.01 1.01 1.01 1.01
1.7 1.51 1.33 1.17 1.12 1.1 1.08 1.07 1.06 1.05 1.04 1.03 1.02 1.02 1.02 1.02 1.02 1.02 1.02
1.72 1.52 1.34 1.18 1.13 1.11 1.09 1.08 1.07 1.06 1.05 1.04 1.03 1.03 1.03 1.03 1.03 1.03 1.03
1.74 1.54 1.35 1.2 1.14 1.12 1.1 1.09 1.08 1.07 1.06 1.05 1.04 1.04 1.04 1.04 1.04 1.04 1.04
1.77 1.57 1.38 1.22 1.17 1.14 1.12 1.11 1.1 1.09 1.08 1.07 1.06 1.06 1.06 1.06 1.06 1.06 1.06
1.79 1.58 1.39 1.23 1.18 1.16 1.13 1.12 1.11 1.1 1.09 1.08 1.07 1.07 1.07 1.07 1.07 1.07 1.07
1.8 1.6 1.4 1.24 1.19 1.17 1.14 1.13 1.12 1.11 1.1 1.09 1.08 1.08 1.08 1.08 1.08 1.08 1.08
1.82 1.61 1.42 1.25 1.2 1.18 1.16 1.14 1.13 1.12 1.11 1.1 1.09 1.09 1.09 1.09 1.09 1.09 1.09
1.85 1.64 1.44 1.28 1.22 1.2 1.18 1.17 1.15 1.14 1.13 1.12 1.11 1.11 1.11 1.11 1.11 1.11 1.11
1.87 1.66 1.46 1.29 1.23 1.21 1.19 1.18 1.16 1.15 1.14 1.13 1.12 1.12 1.12 1.12 1.12 1.12 1.12
1.89 1.67 1.47 1.3 1.24 1.22 1.2 1.19 1.18 1.16 1.15 1.14 1.13 1.13 1.13 1.13 1.13 1.13 1.13
Here's what it was:
1.67 1.48 1.33 1.27 1.21 1.14 1.06 1.04 1.08 1.07 1.05 1.03 1.02 1 1 1 1 1 1
1.62 1.48 1.33 1.27 1.21 1.14 1.07 1.05 1.08 1.07 1.06 1.04 1.03 1.01 1.01 1.01 1.01 1.01 1.01
1.62 1.5 1.33 1.27 1.21 1.14 1.07 1.05 1.13 1.11 1.07 1.05 1.04 1.02 1.02 1.02 1.02 1.02 1.02
1.62 1.52 1.34 1.27 1.21 1.15 1.08 1.07 1.14 1.14 1.07 1.05 1.04 1.02 1.02 1.02 1.02 1.02 1.02
1.65 1.54 1.35 1.28 1.22 1.16 1.1 1.09 1.14 1.14 1.08 1.06 1.04 1.03 1.03 1.03 1.03 1.03 1.03
1.67 1.56 1.37 1.29 1.23 1.17 1.15 1.12 1.14 1.14 1.08 1.06 1.04 1.04 1.04 1.04 1.04 1.04 1.04
1.67 1.56 1.39 1.32 1.26 1.2 1.17 1.15 1.14 1.14 1.08 1.06 1.06 1.06 1.06 1.06 1.06 1.06 1.06
1.67 1.58 1.41 1.33 1.27 1.21 1.19 1.16 1.14 1.14 1.08 1.06 1.06 1.06 1.06 1.06 1.06 1.06 1.06
1.69 1.58 1.42 1.34 1.28 1.24 1.21 1.18 1.14 1.14 1.08 1.08 1.08 1.08 1.08 1.08 1.08 1.08 1.08
1.69 1.6 1.44 1.35 1.29 1.25 1.23 1.2 1.15 1.14 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09 1.09
1.72 1.62 1.46 1.38 1.32 1.28 1.25 1.23 1.18 1.14 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11 1.11
1.72 1.62 1.46 1.38 1.33 1.3 1.28 1.25 1.18 1.14 1.12 1.12 1.12 1.12 1.12 1.12 1.12 1.12 1.12
1.75 1.62 1.47 1.4 1.34 1.3 1.28 1.26 1.18 1.14 1.13 1.13 1.13 1.13 1.13 1.13 1.13 1.13 1.13
Old Nov 12, 2004 | 05:39 PM
Pro Mouse's Avatar
Hey Thanks for the Help Jimmyblue!I am gonna give it a shot tonight to see what my map is at what ect.It should get cold enough again....
Scott
Old Nov 12, 2004 | 11:08 PM
Pro Mouse's Avatar
Ok Jimmy I went -.1 at the MAP vs ect I needed and it deffinately helped.....
Old Nov 13, 2004 | 09:49 AM
Pro Mouse's Avatar
Ok I started up my car this morning and took right off,No chugging ect...The -.1 you told me to go Jimmyblue worked very well I think I will leave it there Thanks again...
Scott
Old Nov 14, 2004 | 09:36 AM
Another_User's Avatar
I am not exactly having any problems with chugging, but I have seen some weird O2 stuff before my car warms up. Almost all the way until the car is warm the O2s are 30-130ish mv, which seems way too low to me. Then the car warms up, the trims go positive when it goes into closed loop. But when the car finally warms up the trims go negative at idle. There seems to be some problem in my a/f ratio until the car is fully warm. Any ideas on where to start?
Old Nov 14, 2004 | 10:52 AM
P Mack's Avatar
Closed loop ect threshold maybe?
Old Nov 14, 2004 | 01:00 PM
Aha....interesting. I watched my trims go right as soon as my air pump shut off today.
Old Nov 15, 2004 | 09:14 AM
Ragtop 99's Avatar
Just to be sure, I'm messing where it needs it most, the MAP readings where idle normally occurs is closer to 100? So unusually high MAP readings refers to idle occurring like around 70 - 80.
I always get turned around on MAP readings.
Old Nov 15, 2004 | 09:32 AM
P Mack's Avatar
Normal idle is more like 50's at sea level, and 40 at my altitude (edit: with my 222 cam). 70-80 is high, which means lower vacuum with a big cam.
Old Nov 15, 2004 | 09:34 AM
jimmyblue's Avatar
Moderator
On my stock motor car, idle MAP is about 35-38kPa. This
is like 20ft above sea level so my low-RPM WOT MAP is
about 100-105kPa. Big cam cars have lower vacuum
(higher MAP) than mine, I worked on one w/ a T-Rex
that idled about 80kPa MAP and have seen logs off
224-series cam car that was 60kPa or so.
Old Nov 15, 2004 | 09:38 AM
jimmyblue's Avatar
Moderator
Yeah, almost like blowing a bunch of fresh air past the
O2s messed them up, or sump'n.
Actually I think AIR pump shutoff is supposed to coincide
with closed loop enable (though, I bet there are ways you
could make those events diverge). I guess this says that
to really tune cold idle right you would want to suppress
the AIR pump.
By Brett Foote | 2026-06-04 05:00:17
