LS1Edit - reduce timing/fuel?
HC = 1.36 (limit .60)
CO = 13.35 (limit 10.0)
The inspection tech said this means unburned fuel is in the exhuast and the timing is too advanced.
Is there a better instruction manual for LS1Edit now; how do you reduce fuel/air ratios and timing? It has been so long since I worked with this program that I forgot how to use it.
Thanks..
Thanks..
OK so I download the current program and save it to a disk. Then I find the high octane table and reduce the RPM numbers across the board by 3-5%.
Is the high octane table a separate tab?
Is there a manual on the software now or is it the same junk that is impossible to understand?
Thanks...
Thanks...
The high octane table is a seperate table
NO & YES
So I think the deal is:
Go to Engine Calibrations tab
Go to Ignition tab
Go to high Octane Spark Advance tab
Go to RPM column
Edit whole table frame (multiply by 95) providing a reduction of 5%
Right?
Thanks...
Go to Ignition tab
Go to RPM column
Right?
Thanks...
you are correct Sir I put some new 02 sensors in and some MSD plug wires. The old O2s were really black (too much fuel).
What is the gismo on the fuel rail that is held in by a snap ring; I thought it was a fuel pressure regulator. No parts store listed this part, however. One of the codes I was showing a few weeks ago was a high fuel pressure reading in the fuel rail (passenger side)?
Is the "idle and curb" test done while the car is using the high octane table?
Is the low octane table only used when the knock sensors detect detonation? Is it possible that since my cam is larger than stock that the knock sensors are telling the PCM to use the low octane tables?
Also there is a tab for idle fuel, one for base timing, and then the VE table. Reduce the VE table as you would for most cam tuning, reduce the first column I think its 400rpms x70%, then next one x75%, and so on up to the 1200rpm column (hang with me here, I havent touched edit in 8 months due to my current deployment maybe off a few rpms on the columns). Tweak the tables a little and save the new one as Etest. Good luck man.
My engine runs a lot different (stronger?) now. I need to check my Ltrims with another computer program (OBD2) to see if I am in the ball park....
I did not see a way to reduce the RPM values at the top of the table. I'm I missing something?
2004 Allowed HC = .60 gpm (my test = 1.36 - fail)
2004 Allowed CO = 10.0 GPM (my test = 13.35 - fail)
2004 Allowed Nox = 1.5 gpm (my test = .82 - pass)
Last year the test was easier for the same make and model car (99 F-body)
2003 Allowed HC = .80
2003 Allowed Co = 15.0
2003 Allowed Nox = 2.0
This seems unfair to retroactively tighten the emmessions standards two years in a row - AFTER the car was manufactured.....
