Will HP Tuners correct pcm for hotcam install
I am looking at doing a hotcam install on my 01 and was wondering if hp tuners is up to the task of straightening out the programming after the cam install. I realize there are other cams out there but I have had good luck with the general's performance parts packages in the past and prefer not to change. But If I cannot get the prgramming right I am screwed. Any help or suggestions would be nice. It is an A4 w4:10's longtubes lid and magnaflow with no cats.
For a fairly stock vehicle what can I put in her to get more low and midrange punch. I'm open to suggestions but do not want to run a stall or trash the gas mileage to bad or get into valvetrain reliability issues. It gets driven about 3000 miles a month give or take. If you have a cam you like please leave the manufacturer and the part # so I can obtain it thanks.
I think I just got my last problem with my tune ironed out (man I hope so). If so it will have a hotcammed car that idles almost like stock at 900rpms, can cruise at 1500rpms, and hauls with a MAFless tune. I'll post the tune on the share site if it works out this time.
Oh crap...I just remembered...I'll probably need some touch-up work after my Shaner S3 goes on...LOL!
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Moderator
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Well, if you have the first "canned tune" for a Hotcam
then that's worth putting up, TB or no. I don't think
anything before the intake manifold matters to SD as
the MAP tells you all about what got in.
