AIR/FUEL Ratio number???
Old Dec 11, 2004 | 08:49 PM
95_Firehawk_Dude's Avatar
Question AIR/FUEL Ratio number???
What is "normal" air/fuel ratio number? I.E. When you get your car dyno'd, below the HP/TQ numbers there is a graph of the air fuel ratio with the RPM your at? What is that supposed to be so to speak? Higher number on the left mean rich or lean?
Thanks
Old Dec 11, 2004 | 10:04 PM
wait4me's Avatar
you want about a 12.8 straight accross normally for naturally asperated cars, anthing lower may hurt performance, and a higher number means you are running lean, and too lean is bad.. jes
Old Dec 12, 2004 | 01:13 AM
Would to lean mean that more power could be pulled out of it or is that when your running to rich? I.E. when they tune your car... how are they getting more power out of it?
Thanks.
Old Dec 12, 2004 | 02:18 AM
chpmnsws6's Avatar
13.1 N/A makes the most power and is not lean at all.
Old Dec 12, 2004 | 02:32 AM
BlackCamaroSS02's Avatar
What would be a good ratio for Boosted cars...mine was 11.6 A/F i think.
Old Dec 12, 2004 | 04:26 AM
So what would you make of this? A/F part of dyno run.
If you can't tell from the pic, its kinda goes like this:
18 from 2000 to 2300 rpm
16 @ 2400 rpm
15 @ 2600 rpm
14 @ 2800 rpm
13 @ 3000 rpm and stays until 4500 rpm
12 @ 4500 rpm and stays until 5500 rpm
11 @ 5500 rpm
Is the car running to lean? Rich? What else can you make from it?
Thanks.
Old Dec 12, 2004 | 06:10 AM
2MuchRiceMakesMeSick's Avatar
Thats waayy too lean at lower RPMS. Fatten it up to about 12.8 - 13.1
Old Dec 12, 2004 | 09:02 AM
wait4me's Avatar
that tune is way off, from that run. the car shouldnt ever hit a 17. normal is 14.7 for na car and if tuned to a 12.8 it is safe, so what if you gain 1 horsepower for running a 13.1 if its a blower car, i like to hit 11.9 to 12.1 it depends on the car and what kind of exhaust it has. that car may have other problems with fueling, or just the tune is way off, jes
