LM-1 wideband effort
Old Dec 29, 2004 | 06:33 AM
Debian Dog's Avatar
Default LM-1 wideband effort
What's you guys opinion in making the effort to convert the car to run off the wideband 02 sensor instead of the factory ones? I know the PCM does not use it for WOT but... Ir seems like it "may" be worth it.
Thoughts?
Old Dec 29, 2004 | 11:35 AM
Project GatTagO's Avatar
If your tuning is on the money, there is no reason to have a wideband O2 sensor installed in the car. If your tune up is good, then theoretically you can just run in open loop all the time.
Andrew
Old Dec 29, 2004 | 01:03 PM
jimmyblue's Avatar
Moderator
The PCM wants a sensor with the switching characteristics
of the narrowband sensor. You might be able to fool it with
the right programming and output levels but I don't believe
there is anything to be gained by emulating a narrowband
with your WB unit.
Old Dec 29, 2004 | 01:10 PM
Debian Dog's Avatar
Thanks All!
Old Dec 29, 2004 | 11:07 PM
618HAWK's Avatar
with your WB unit.
So what are you saying a wideband sensor-system is no good. I understand that if your tune is on the money it would not be necessary. But on the other hand it would not hurt to know what your a/f is realy doing. Granted it will cost to monitor it but could save some major problems down the road.
At least with a standalone wideband you would know where you stand while in day to day driving conditions.
I have heard the that normal a/f gauge systems are not all that correct, bounce all over the place-light show.
dont take me wrong I am open for any creative input.
Old Dec 29, 2004 | 11:55 PM
jimmyblue's Avatar
Moderator
No, I'm saying that for the GM PCM to operate as designed
you want the narrowband type of response in a switching
mode.
If it was a linear, real-time type of control loop a wideband
would be better, but that is not the case at hand.
The wideband meter is useful for non-stoich tuning and
I have one. But, it is out-of-place in the application DD
described (substituting for the narrowband type that the
stock PCM expects). You could probably fake the wideband
into looking like a narrowband but that's about $300 worth
of pointless.
Old Dec 30, 2004 | 12:59 AM
pekkaz's Avatar
It should be possible to emulate stoich switching at some other than 14.7 afr. I'm not sure if LM-1 can do this but technically it is well feasible and could be useful, if you want to run closed loop for some target afr...
Old Dec 30, 2004 | 10:39 AM
jimmyblue's Avatar
Moderator
You can set the transfer function pretty arbitrarily, and if
you made the transfer function very steep but offset to the
target AFR, made the range 0-1V and eliminated the "smoothing",
then it might be fast enough to play well. The LM-1 has two
separate outputs so you could have one faked this way and
the other set up for logging (nice, slow and linear).
Old Dec 30, 2004 | 11:40 AM
618HAWK's Avatar
mode.
of pointless.
Oh thanks JIMMYBLUE. I understand know.
Old Jan 2, 2005 | 07:45 PM
Mike Mercury's Avatar
without a WB 02 sensor, you'll never know if your tune is " on the money" or not - at WOT.
I see hesitation from many over installing an additional sensor bung; but I can't figure out why ??? My local muffler shop installed one for me - for $15; complete with cover and all.
I install my LM-1 sensor, make some runs, make tuning changes, verify changes with a few more runs... then I'm done with it. I remove the WB sensor, instal the cover and put the LM-1 away until I make changes under the hood again.
Old Jan 2, 2005 | 09:08 PM
slow's Avatar
Ditto, My car has wideband bungs on both sides of the Y pipe for tuning.
Cost, $5 for the 2 18mm plugs, and nuts, and about 1 hour of time, to pull the Y and have my friend weld them on.
Ryan
