Factory PCM's RPM Limit:
Originally Posted by wait4me
i just brought up the posibilitys of problems that might happen, sorry if all this got out of hand, the limit of the pcm is 8000 to be accurate, anything more and you loose the ability to change what is going on in the pcm. it references that last point when it left the table.. so if it left at 60 gm/s then it would hold that value in that cell untill it reentered the table at under 8000 rpms. the coil issue i would think will cause you a problem, they arent designed to go to 8000 rpms, .. but thats just my own oppinion, recharge time aint the full ballgame i would think, and it seems kindof hard to think that they could fully put out a full charge that fast... seems odd that gm would go and put on a part that would go that far if they never intended to go there... ?? sorry guys.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
