Torque managment question?
Old Jan 22, 2005 | 08:11 PM
BURN'EM's Avatar
Default Torque managment question?
In a built trans that has mechanically raised the line pressure and using heavy duty billit servos, can TQ managment cause the TC clutch not to lock up in OD? Mine goes in and out of lock up after the rebuild. I still have TQ managment to 100%. What needs to be done?
Old Jan 23, 2005 | 08:53 AM
wait4me's Avatar
are you seeing missfires with your cam?
Old Jan 23, 2005 | 04:36 PM
BURN'EM's Avatar
no misfires that are enough to trigger it 47 - 60 a minute. I can't figure it out.
Old Jan 23, 2005 | 04:52 PM
wait4me's Avatar
try killing the low and idle missfire tables and see if it fixes it, you can alway put them back if it dont work. jes
Old Jan 23, 2005 | 04:54 PM
wait4me's Avatar
another thing, when you installed the lockup soloniod, did you check it for cracks? it needs checked.. a small crack will loose pressure just like you are saying. jes
