Let's see your VE graph after tuning..
#41
Originally Posted by sscam68
You've got some serious smoothing out to do! ![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Throttle Response is night and day difference.
#42
Originally Posted by Magnus
Using VCM Suite 2.0:
(VE table of the NA SI record LS1 tuned in only open loop SD)
![](http://www.hptuners.com/pub/keith-ve-2.jpg)
BTW: 2.0 sure does look nice.... Need a beta tester.
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#43
LS1TECH Sponsor
My AFR table is modified but only to command the desired AFR I am looking for at those cell values... The stock table is not meant to be run full time. It's a bit rich in places. ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
If my table was not smooth the throttle transitions would suck.
Log commanded AFR to see what your PCM is trying to obtain.. If your tune is stock you may not like the values you see in a SD vehicle.
#44
#45
Originally Posted by Black02SS
I have altered my AFR multiplier table to give me a 14.737 AFR at all times. I have my Stoich value at stock (14.62857) and altered my AFR multiplier table to result in 14.737 for all maps up to 80kPa. I then adjusted the VE table to result in the commanded AFR of 14.737. Is this not the correct way to achieve this?? My throttle response/transition on my car seems awsome.
#47
LS1TECH Sponsor
I have a multiplier of 1 on my AFR table for all cells above 140 F.
I use PE to increase desired AFR under load. I know as soon as my car is in PE by the change of the commanded AFR as I only run 2 AFR's.. but I also only tune for a very narrow temp range as I race with no thermostat.. In more normal driving conditions I would modify my AFR table to be more temp friendly.
#48
https://ls1tech.com/forums/attachmen...chmentid=25125
PS. Would still like to help beta test 2.0 if you need someone....
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#49
LS1TECH Sponsor
Definately.
You can see bumps at various parts of the table caused by various intakes and h/c combinations.. but the transition between the bumps and the surrounding areas should be smooth.
#50
Definately.
#51
LS1TECH Sponsor
Your VE table needs a major overhaul.
VE does not change your commanded AFR.. your AFR and PE tables do..
With your commanded AFR table and PE table set to the AFR you desire, your PE table should generate a AFR (use your WB O2 to log) that matches your commanded AFR.
Also, disabling the LTFT's helps when you tune the VE table.. re-enable when you are done.
The AFR Commanded Error histogram in HP Tuners VCM Suite makes VE tuning a snap.
Be sure to log the commanded AFR.. I think there may be a couple spots in your tune that may be throwing your VE table off which is why it may look the way it does yet your car still drives fine.
#53
LS1TECH Sponsor
Changing the VE does not affect commanded AFR.. it affects ACTUAL produced AFR.. which you can verify with a wide band against the commanded AFR to see how true your VE table really is.
#55
#56
#58
LS1TECH Sponsor
Have you tried hitting the smooth button on that VE table just once? Reload the table with 1 decimal of precision, then hit Smooth.. try that.
Your WOT VE worries me. Its flat across the board, you might want a peak torque ridge.
When you look at your VE table.. picture a cursor going over the VE table as you experience various parts of driving conditions.. as it goes over very drastic conditions you may notice a slight hickup in the way the car responds. A smooth VE table will result in smooth transitions.
Also, its easy to tune the low rpm low kpa cells of the table as you are in them quite often, however high load low rpm you may barely hit.. so you will not get a lot of data in that range.. When you do hit those cells, adjust the surrounding cells as well (by a lesser margin) to keep things inline.
If you log one cell and only one cell and log 1000 frames.. and you need to add fuel, if you add +10 to that cell, add +5 to the surrounding cells.
Every time I change a cell I change the surrounding cells to a lesser degree.
I use the multiply by half % feature when I paste in my histograms to my VE table.
#59
#60
LS1TECH Sponsor
Originally Posted by HumpinSS
Understood. But dont you want to see commanded and actual match hence movin the ve table until that is acheived?
I though the pe table was a multiplier of stioch. 14.7/1.13=13.00 commanded and then you tried to get the WB to match this for actual
