LM1 EIO question, WB02 says 14.8 HPT fluctuates..
The display is slower, always. U can change the calibration of both HP tuners and the LM1 analog output min to 20 and 25 max AFR. U can then see which is correct.
the only thing I saw in HPT to change was the formuals for V vs. AFR. I dont follow what you are saying exactly but what I did was flatline the voltage. 0-20 AFR always output 2.40V. When i did this any AFR should display 2.40V, I was getting 2.42V out of the LM1 which is very close. Is that what you were saying to do only at 20AFR?
Dave
Dave
