Time to talk dyno's
This is also very true. I actually didnt buy my dyno for numbers, I wanted a usable running car in the end. I want a car that responds in every situation. Its funny if you talk to the guys from dynapack and ask them how you do hp tests, and from how they talk, they didnt realy design the dyno for that purpose either. Its more of a real tuning tool the right way IMO. So since the internet is full of "How does that cam sound?" and "What kind of power did that cam make?", you can see where the dyno is being missused.
rick
Again, I have nothing against the MD, I use it all the time as well. I have had awsome results with it. Plus your right about the 1/4 mile sim, its pretty damn accurate.
Rick
When it comes to a dyno I feel that each serve there own purpose. You have to realize that alot has changed in the last 10-15 years when it comes to dynos. Most of them weren't design for tuning fuel injected vehicles they were designed to analyze power at different curves. Mainly carbureted or manuel injected vehicles, where you wouldn't be able to make a change until after your run was complete.
Now things have changed and so has the way in which we use the dynamometer. It wont be long before OBDIII hits the market place and a lot more thinking has to come into play.
Sorry I just took off rambling...it's late and I just finish the work I had to take home.
Another good point. But I find that after checking the Air/Fuel RPM by RPM, then I do a sweep test, it runs better because the A/F is where it should be and when it ramps up like on other dynos, the curve is smoother and easier to adjust.
But with Top Fuel, thats why they never dyno those motors. They dont hold together long enough. Never meant to dyno. Just run once.
Rick
Please show me the dyno that runs these motors!!!!
Thats why its nice to have an open wheel racer, your power levels are not out of range for most dyno's
It is supposed to be able to control 1000 HP for stepped and steady state tuning.
I opted to spend the extra $20 for the very reason posted in the beginning of this thread. Tuning.
We'll see how it works in a few weeks. If it works as advertised, it will be a great addition to my shop.
By the way Rick, most Top Fuel (now I mean Top Fuel this time) I've seen are usually torn down after every pass. In fact I have even watch them be re-ring while still in its cage.
Thank goodness Ben didn't read this he would be giving me hell right now!
The most commonly found are:
Dyno Dynamics - http://www.dyno.com.au/home.htm
- most popular
- put a lot of effort into the so called "Shootout Mode" which is a certification on software, usage and practices to ensure consistent results on all dyno dynamics dyno's
Dynologic - http://www.dynologic.com.au/
- generally regarded as a "premium system"
- very good software
- large rollers
- used by a few leading raceteams
- also make great engine dyno's
Dynapack - http://www.dynapack.com/
- bolts directly to rear axles eliminating tyre slip/pressure variables
- used for accurate results and repeatability
- can be used to test axle tramp and clutch performace, and some aspects of suspension dynamics
- very good software also
I've mostly used the Dynologic setup, both engine and chassis dyno's. However, i have done some stuff on the Dynapack and it is quite impressive.
In regards to tuning, it is sometimes very difficult to tune the light load area's of an SD tune on the chassis dyno as the resistance is just too high to get those "coasting along" cells in a VE table.
Anyway, my 2c.
Chris...
as much or little load as you desire, static loading, repeatable, no wheel slip
hands down best dyno on the market.......IMO
