Why is the LS1 slow to rev down?
<small>[ February 28, 2003, 02:38 AM: Message edited by: Midnight F-117A ]</small>
<strong> There is a motor used on the throttle cable which brings the rpms down slowly, so the LS1 does not stall after the rpms drop quickly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif"><img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Where is this throttle motor you speak of?
<strong> There is a motor used on the throttle cable which brings the rpms down slowly, so the LS1 does not stall after the rpms drop quickly. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">What motor? There's only a cruise control motor on the throttle cable. If you took that off and watch it while revving the engine it does not do anything at all. Even revving it manually by roating the throttle blade bellcrank, it still does it. I believe it has to do with the injectors and the PCM controlling it.
when hot it stays up there which I think makes it easier to shift faster and smoother when power shifting
I have a 2000
