New MAF Table Spreadsheet and RAF Table
So the excel sheets WILL get you very close then if you are a perfectionist like me, you can tweak till you are happy.
I agree the MAF table does work great.
it would be nice to run the same set of numbers though and compare the results, just to verify the math though...any volunteers?
1) Mafless Tune the VE with PE disabled till all values 0 to -2
2) Plug back in MAF/ Re-enable PE and use this spreadsheet to adjust maf using MAF table till values are same as prior to MAF installation.
3) Then tune PE with a wideband!
so:
step 0:
SD mode
step 1:
do a full table VE tune, like you were trying to stay MAFless (gather good data for MAF ironically enough)
step 2:
put in your new VE and MAF tables, might as well throw in PE in there too, as that's just pure math.
step 3:
drive around some more in SD, to validate your VE, and gather up some more MAF data (as you can compound data from different runs in version 2.5 of my spreadsheet)
step 4:
put in your final MAF and VE changes (usually very minor, consider it 'smoothing')
step 5:
back to MAF mode, and go scan again, everything should run as well as it did in SD (as that's what MAF calibration does, makes calculations agree with sensors).
v'oile!
note: combining VE and MAF calibrations really cuts down the time, twice this week i already did a full tune for two different cars, and they both run perfect now (well, i never touched timing, but that's a whole different ball of wax). took about an hour each
man, if i could only get paid for this stuff...
Another_User:
either PM me your email account, or just talk to me on aim/yahooIM/icq, they're all in my profile.
I've downloaded new sheet several times and made new scan logs and it keeps doing the same thing. Can you tell me what I'm doing wrong now verses the first time when it worked? Thanks guys!
www.allmod.net/hpt My thinking is that if I pick values that emulate the shape of the Monaro table to complete my table, then 3rd order curve fit it, then input the frequency into the equation and solve for airflow, it should give me a very nice smooth curve. Right? (The curve that the spreadsheet output wasn't as smooth as the example curves.)
While I'm here, how do I get data above 9kHz? Just go faster? (Or will that not matter? 9kHz was about 80mph and 80kPa MAP. Maybe I'll have to log some drag strip runs this weekend to get better data...)
2. what i do is use my new calibration points (assuming i got a good calibration from LOTS of samples) I graph these new points on XY graph, put a trendline through it (polynomial, 3rd order) and tell it to give me the equation for the best fit line. the equation is usually _very_ long, so you might wanna crank up the 'decimal resolution' on the displayed equation (to the full 30digits preferably, you'll see why) and use it to create the values for points that you haven't it yet. I consider this to be a more academic point, as if we haven't hit it in testing, we probably won't hit it in real life, but just in case, i'd rather have my calibration full and without any jerkiness to it. give it a spin.
best yet, talk to me on AIM, i'll show you more tricks. btw, i love that vette of yours!
1. Ok, I'll log more and get more samples. My first attempt was just using about 25 minutes of mixed driving. I was pleasantly suprised to see that the data trended very closely to the Monaro table (which I was using before I started SD tuning).
2. That's what I was planning to do. I guess I didn't explain it well. I'm Scooter70 on AIM. I'll add you to my buddylist and talk to you when I have more data to sort thru. We're going to the drag strip on Saturday so I should have more data between now and then. (And I'll get a chance to see what this car will do...) Thanks for the kind words. It was a very interesting learning experience. My next project should be even better.
-Matt
i.e. if the AFR is 14.7 and the fuel flow is 100 lbs/hr, then the mas airflow is 1470lbs/hr.
100lbs/hr x 14.7 = 1470lbs/hr
Once you have airflow in lbs/hr, you can compute standard CFM.
1 standard cubic foot of air weighs .0745lbs.
so, 1470lbs/hr / 0.745 = 19730cf/h , 1973cf/hr / 60 = 329CFM
With that, RPM and your engine displacement, you can get V.E. directly.
To do this, you need a wideband that can keep up with fast airflow changes (LM-1 or LC-1), and to log RPM and injector duty cycle.
If you can log your MAF sensor output, you can map its output and get CFM/V or CFM/Hz.
If you have a rising rate fuel pressure regulator, you will need to log fuel pressure also. Good idea to log TPS too; since your really only want WOT data.
Fuel flow can be calculated from the standard formula.
I put the fomulas here: Still working on the formatting.
http://67.43.173.134/StupidWidebandTricks.htm
If it seems like allot of math, we are automating it and putting this all into Logworks 2.0
