New MAF Table Spreadsheet and RAF Table
Old May 5, 2005 | 03:56 AM
  #61
dr.mike's Avatar
Originally Posted by RedHardSupra
oh wow this is cool! why didn't i think of this? i have a spreadsheet that is one step away from this! alright, i'm off to update it with this formula of yours
almost forgot.
AirFlowg/s = AirFlowlbs/hr x 0.126
Old May 5, 2005 | 11:23 AM
  #62
RedHardSupra's Avatar
check it out, and let me know what you think:
http://redhardsupra.blogspot.com/200...olumetric.html
Old Jun 11, 2005 | 04:21 PM
  #63
vette.se's Avatar
Ok, what am I missing here ??
I've tried the spreadsheet on two different computers, one with Office 2000 and one with Office 2003 - same result on both.
I paste the RAF table in 'Idle tables 98-00', I paste the gathered data in the 'Data' sheet (exactly the Pids that are listed in the Readme sheet) and hit the 'Calculate RAF' button. It starts working showing the 'Data' sheet, after a while all cells starts to flicker and it hangs there for a long time and when I get a Run time error 91.
Any ideas ?
I'm only interested in the RAF part because I have no MAF (Running in SD all the time).
Thanks
Old Jun 11, 2005 | 06:49 PM
  #64
02sierraz71_5.3's Avatar
Any ideas ?
Thanks
I get the same thing normally run time errors are a problem with math or something is looping dividing by 0 etc..
Old Jun 11, 2005 | 09:54 PM
  #65
Robert56's Avatar
Yea, I got the run time error 91 also, couldn't figure it out. E-mailed one of the authors but no answer? I finally used soundengineer's spreed sheet with great results.
Old Jun 12, 2005 | 01:44 AM
  #66
Dixit's Avatar
I remember getting this error because I didnt log all the PIDs. I was only trying to calibrate the RAF table and only logged the STIT and LTIT pids, I didnt bother with the MAF Hz and others. Then I got the error.
Went back to a scan that I had all the PIDs and it worked fine. It looks like his programming is looking for all PIDs for some reason. So I just add them all that he needs when using his spreadsheet.
Dixit
Old Jun 12, 2005 | 11:26 AM
  #67
Robert56's Avatar
As far as I know I had all the pids and the ones specified. Because when adding dynamic/cly had to drop one in order for this addition?
Old Jun 16, 2005 | 01:41 PM
  #68
vette.se's Avatar
Tried everything I can think of but can't get this to work.
Is there any alternative to calculate the RAF numbers. Someone else made a spreadsheet ?
Thanks.
Old Jun 16, 2005 | 01:53 PM
  #69
hey, Chad, could you gimme a rundown on how it works, and i'll make it pure excel so it always works, not some VBA crap ?
Old Jun 16, 2005 | 03:38 PM
  #70
Black02SS's Avatar
I will look again at it tonight at work. I will fix it but do not want it to be in straight excel. **** takes too long and won't auto find.
Old Jun 16, 2005 | 04:16 PM
  #71
<darth vader voice> I find your lack of faith disturbing
Old Jun 16, 2005 | 05:18 PM
  #72
Black02SS's Avatar
My sheet works just like yours does, except mine doesn't require the user to input the correct data into a certain column and wait for the output. Really not that big of a deal, if I get a chance to work on it I will. I have since sold my HPT and have no use for it to be honest as EFI Live does all of this for me already.
Old Aug 21, 2005 | 07:42 PM
  #73
DaleMX's Avatar
The Link doesn't work any more.
Old Aug 21, 2005 | 07:43 PM
  #74
Black02SS's Avatar
Sorry for the inconvience. I have since removed the link to the spreadsheet and no longer support it. I have changed from HPT to EFI Live and there is no need for me to have it any longer.
Old Aug 21, 2005 | 09:40 PM
  #75
there shell be no fear, cause I is here!
www.allmod.net/hpt/RAF_1_1.zip
enjoy, test, report
Old Aug 21, 2005 | 10:37 PM
  #76
Black02SS's Avatar
