EVAP messing with WOT cells
Can I get rid of this happenin somehow ? Car is a '98 f-body.
only thing that matters is, whether you have a
positive LTFT in those cells. If not, then the
closed loop correction is totally out of the picture
and the fuel air multiplier you get will be from the
PE or OLFA table (presuming other stuff like COT
is not getting into it).
Now, Cell 22 being a sort of emissions-active
catch-all, will probably be harder to get happy
than the rest but if the rest are indeed well tuned
then 22 should follow. But if you have some of the
regular cells with problems then 22 is likely seeing
the same MAP*RPM points and no happier than
the rest.
Though, at WOT EVAP should be inactive and PCM should not go to cell 15.. just makes me wonder if the PCM is still fully OK or does the program start to rot. I have SVO #30 and I would remember someone had this same issue starting after upgrading the injectors on '98 f-body.. would seem to be completely uncorrelated but you never know what bugs may get activated through table modifications
