OBD/Readiness Driving Procedure
Thanks!
and checking
Thanks!
To make the stuff pass just follow this...
You can force them to do the tests here is the list:
For cats to clear the test,
start at idle while engine hot, and accellerate at 3/4 throttle to 55-60 miles an hour than cruise steady at 55 miles an hour for 7 minutes. Do this three times
for the evap to clear :
drive down the highway at 60 mph for 6 minutes, then let off gas and decell with NO BRAKE down to 20 miles per hour then do it again same pattern.
For the evap system:
can only be done after the oxygen and cats monitors have completed,
Intake air temp is within 7 degrees of engine coolant temp,
Cold start engine coolant temp is < 50 degrees celsius, \
Turn on air conditioning and rear defrost on, idle for 2.5 minutes in drive. Before preceding turn accessories off.
Acceleration to 55 miles an hour at 1/2 throttle air conditioning off.
3 minutes steady state cruise 55 then 60 miles per hour, then decellerate to 20 mpr with no brake.
then accerate at 3/4 throttle to 55 again for 5 minutes
then decellerate with no brake. then that test will pass when this is done.
Air injection test needs a cold start , air conditioning on, rear defrost on, and idle for 2.5 minutes in Drive. before proceeding turn all accessorsy off, then drive 55 mph for 3 minutes and it will pass
https://ls1tech.com/forums/midwestern-members/287724-another-emissions-question.html
https://ls1tech.com/forums/showthread.php?t=287724
In Ga. you do fail for readiness monitors not being set but have 30 days to get them set and recieve 1 free retest. Here you can have 1 not ready for 01 & up cars and 2 not readys for 00 and older cars and still pass.
Catalytic Converter
Secondary Air Injection
Evaporator System
start at idle while engine hot, and accellerate at 3/4 throttle to 55-60 miles an hour than cruise steady at 55 miles an hour for 7 minutes. Do this three times.
When I do this do I need to shut the car down in between the three runs?
Thanks, keep you posted
Re'
I have my car in OLSD in process of tuning (ie cat over temp disabled, etc)... What needs to be active in order to pass all the readiness tests when they scan OBDII?
I'm wondering if I should go back to my old predator tune where everything was on (cats, o2, maf, etc) and then go back to OLSD when passed?
This is absolutely ridiculous what we have to do to pass inspection. Yes the battery was disconnected for 15 minutes.
I am guessing the three times have to be consecutive? Or can it be done over three days?
