Autotapped the car today, need help interpreting
I'm learning about this stuff but I would really like some input and analysis from you guys who know a whole lot more than I do. From what I can see and watched as we logged, I get detonation and a good bit of KR from ~1500-2000 RPM. I didn't see any during WOT, only immediately after when I let off. I also see that my fuel trims are all over the map.
Excel spreadsheet: http://www.slowls1.net/autotap_4505.xls
RAR of raw Autotap logs: http://www.slowls1.net/ataplogs.rar
We also scanned the DTCs, it isn't setting a MIL at this time but in the freeze frame we found these codes. I have snapshots of the information stored at the time each code was set, if you need to see those please let me know.
P1134 HO2S Transition time ratio bank 1 sensor 1
P0131 HO2S Circuit Low Voltage Bank 1 Sensor 1
P1637 Generator L-Terminal Circuit
P1626 Theft Deterrent Fuel Enable Signal Not Received
Could the B1 o2 be the problem, ie, cause a bad enough lean condition resulting in the detonation I'm hearing and seeing? Can I switch to a Corvette rear o2 for B1 only, and might that fix my problem? Anything you guys can tell me based on what you see in the logs will be greatly appreciated.
