Get It Tuned???
Old Apr 10, 2005 | 10:25 AM
WANARUNM's Avatar
Default Get It Tuned???
IVE GOT A 99Z RUNNING A 13.10 QUARTER WITH THE HYPERTECH PROGRAMMER III. THE CAR IS HAVING A CAM UPGRADE WITH ENGINE REBUILD RIGHT NOW. IS THERE A BIG DIFFERENCE IN THE TUNE I GET FROM THE HYPERTECH PROGRAMMER VERSES HAVING THE COMPUTER "TUNED" AT A SHOP? ANY INPUT HELPS
Old Apr 10, 2005 | 10:27 AM
foff667's Avatar
LS1TECH Sponsor
Shut Off Caps Lock And Yes There Is A Big Difference!!!
Old Apr 10, 2005 | 12:46 PM
WANARUNM's Avatar
hows that
Old Apr 10, 2005 | 01:38 PM
foff667's Avatar
LS1TECH Sponsor
wonderful, and depending on how big of a cam you get your car will barely idle out of its own way upon initial startup...thats why there can be a big difference.
Old Apr 10, 2005 | 01:49 PM
mike s.'s Avatar
Your hypertech is not worth a damn for a cam install. You will need to have adjustments made to you idle for sure, and timing and possibly fuel for optimum power and driveabilty, upgrading injectors can benefit a cam install sometimes as well. The only software I would recommend is ls1 edit and hp tuners, look for some tunershops in your area, remove the hypertech program and sell it on ebay to offset the cost. Every thing you have done with your hypertech can easily be copied and improved with dedicated pc based tuning software. I have a tune on my near stock 02 z that is almost a carbon copy of the predator tune, with minor adjustments using hp tuners software
Old Apr 10, 2005 | 07:21 PM
WANARUNM's Avatar
Thanks guys that answered my next question-no need to reinstall the hypertech when I get the car back. Whats a decent price for a tune
Old Apr 10, 2005 | 08:52 PM
foff667's Avatar
LS1TECH Sponsor
ive seen tunes that cost $100 and have alot of work in them and have seen tunes run 580 that were garbage.
Old Apr 10, 2005 | 09:08 PM
mike s.'s Avatar
He is totally right, more specifically, there are people who tune them independently you can find them here on the forum, you have to be careful though, you dont want some jack *** screwing your car up. If you go that route, make sure they have wideband o2, and one of the afore mentioned programs on this thread. Adjustments made to timing and fuel can be disastrous without accurate air/fuel ratio readings. I suggest you go to a tunershop, find one that geared towards ls1 engines, the prices I have seen for shop tunes range from $400-$675, anything more than that is a rip, that should include the actual tuning plus dyno time, and wide band capability. If they cannot provide at lest that dont take your car there. Good shops will have a free retune policy plus the cost of additional dyno time so subsequent retunes should be 100-150 dollars. Remember not to let em ram it to ya everytime you need one done.
Old Apr 11, 2005 | 06:29 AM
WANARUNM's Avatar
Cool, I hope do get the car back in 2 to 3 weeks so in the mean time I'll see what I can find around here. Thanks fellas
